How do I program my key FOB?
Old Jun 9, 2006 | 11:25 AM
corvettecorvette's Avatar
corvettecorvette
Default How do I program my key FOB?
The one I had already was a #2 and the one I bought is also a #2. Is this a problem? Will I have to go to the dealer? I'll be away from my computer for aleast a day so please PM any help you can offer. Thanks, Kendall
Old Jun 9, 2006 | 01:02 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
HERE YOU GO...
Transmitter Programming
Each transmitter has a unique Vehicle Access Code (VAC) that changes every 5 seconds. If a transmitter or receiver is replaced, each transmitter must be programmed to the vehicle's receiver. Entering a specific button sequence on the DIC, up to 3 transmitters can be programmed into the receiver. After programming the transmitters to the vehicle, the receiver will update this code every 5 seconds in order to match the code programmed in the transmitter.
The transmitter may not communicate or become out of synchronization with the receiver if any of the following situations occurs:
The transmitter battery is disconnected.
The vehicle battery is disconnected.
The transmitter and the vehicle are separated for 2 weeks or more.
The receiver is disconnected.
Perform the synchronizing procedure if the transmitter does not communicate or becomes out of synchronization with the receiver. If the transmitter and/or receiver are replaced, preform the following programming procedure:
Programming Transmitters
Turn the ignition to ON.
Turn the radio to OFF.
Press the RESET button on the driver information center (DIC) in order to clear any IPC warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the RESET button for 3 seconds.
Press the OPTIONS button until FOB TRAINING message is displayed.
Important
If the FOB TRAINING message cannot be display, check if the BCM is configured with the correct RPO codes.
Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
Programming Cancellation
The receiver will cancel the programming sequence if any of the following conditions occur:
The program mode is exited through the DIC.
The ignition is turned to OFF.
The three transmitters have been programmed.
The RFA system has been in the program mode for longer than 2 minutes and no transmitters have been learned.
If the program mode is cancelled with less than 3 codes stored, the receiver will only accept the codes just stored. If the program mode is cancelled before any code is stored, the codes still remain valid.
The receiver retains all current access codes in memory if either of the following conditions occur:
A programming sequence is interrupted.
The battery is disconnected.
Synchronizing Transmitters
Preform the following procedure if a transmitter cannot communicate or becomes out of synchronization with the receiver:
Move a programmed transmitter within range.
Press the LOCK and UNLOCK buttons on the transmitter simultaneously for 7 seconds.
The horn will chirp once when the transmitter is synchronized. Repeat this procedure for each additional transmitter if needed.
Old Jun 9, 2006 | 07:53 PM
DoubleZ06's Avatar
DoubleZ06
Works like a charm.
Old Jun 9, 2006 | 10:50 PM
corvettecorvette
Thanks a mill bro. I'll do it on Sunday and thanks again.
Originally Posted by RichieRichZ06
HERE YOU GO...
Important
Old Jun 9, 2006 | 11:04 PM
cruisemon's Avatar
cruisemon
Default fob learn
I also found if I stand next to the car and press both lock and unlock buttons simultaeously for 7 seconds it resets as well without having to fool around with the DIC. May have to hold 8 seconds. When the horn blows, the learn cycle is finished.
Charlie
To How do I program my key FOB?
