I have a check engine light problem. I just learned how to check the CODES now found the code 10 pcm PO455 H C.
Now I need to know what this means.
Thanks in advanced for all of your help, you are great.
Since you have an '86 the guys in the C4 section could probably give better help but a loose, incorrect, missing or damaged gas cap can cause this code.
