Engine chirp when first started
Old Jun 10, 2006 | 05:37 PM
twhanks's Avatar
twhanks
Default Engine chirp when first started
I love my 01, but have started hearing a chirp for a minute or so at idle when I first start it. I read many previous posts and took off both accessory belts. No change! The noise almost sounds like it is coming from the RH upper part of the engine. Valve train! I hope not. Any thoughts?
Old Jul 9, 2006 | 02:47 AM
LIGHTNING's Avatar
LIGHTNING
ttt
Old Jul 9, 2006 | 07:56 AM
Nyvetteguy007's Avatar
Nyvetteguy007
Belt Idler pully caused the same problem for me...changed the idler and tensioner...now no noise..
Old Jul 9, 2006 | 08:19 AM
Jay-rod's Avatar
Jay-rod
You don't have to change the tensioner(G.M. sells as a unit-tensioner/idler).Just go to PARTSOURCE and buy the idler for around $20.00.Hope this helps.JER
Old Jul 10, 2006 | 11:12 AM
tompugh's Avatar
tompugh
I seam to be having a similar problem. More distinct chirp or under part throttle in 1st or 2nd gear. Less so at idle when revving the motor in neutral.
What is Partsource (local auto parts store)? Tom
To Engine chirp when first started
