Tail Lights not working Help!!
Old Jun 11, 2006 | 07:55 PM
Corvette1996LT1's Avatar
Corvette1996LT1
Default Tail Lights not working Help!!
Friend of mine has a 2000 vert and he called today wanting me to come over to help him with light problem. He said that the Tail lights don't work and the dash lights are out. Said the headlights work and brakelights come on but the the regular tail lights are out a long with the dash lights. Any Ideas?
Old Jun 11, 2006 | 09:03 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
check fuses. i am not sure about the c5 but many other cars are set up so that if the tail light fuse blows the dash lights also go out to let you know of the problem.
Old Jun 12, 2006 | 12:56 AM
Jeffyvette's Avatar
Jeffyvette
If it is not a fuse, it may well be the multi function switch (turn signal,cruise control, lights) on the left side on steering collum. I had to change mine 2 weeks ago had same symtoms.
Jeffy'
Old Jun 12, 2006 | 07:33 AM
Corvette1996LT1
Thanks for the replys so far I was thinking about the switch as well. He has checked all the fuses and they are all fine.
To Tail Lights not working Help!!
