Simple projects ALWAYS turn to Major Projects!
Old Jun 12, 2006 | 12:01 PM
chuckster's Avatar
chuckster
Default Simple projects ALWAYS turn to Major Projects!
This is the story of my life...
This weekend all I wanted to do was ..
1. Change out some clutch fluid (Turkey Baster Method)
2. Clean my Vararam Filter.
Tops a 30minute job! right? Wrong.. by buddy "Murphy" ensures that it's more complicated..
The Master Cylinder on the clutch now squaks like a parrot now... so I need to Bleed the entire clutch out.. so while I am doing this I may as well add the LAPD Remote Bleeder..
$89 and most likely a day of work...
Then my filter for my Vararam is falling apart. and the base is cracked.. Good news is Vararam is replacing the Plenum.. But still..
$49 plus another 1/2 day replacing the plenum.
Old Jun 12, 2006 | 12:03 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
welcome to my world....
Old Jun 12, 2006 | 12:19 PM
VetteDrmr's Avatar
VetteDrmr
So, your point is????
If you haven't done it before, wait until you try to get the disconnects between the master and slave cylinder disconnected and reconnected (hint, I replaced both and ended up with a hacksaw!)
Have a good one,
Mike
Old Jun 12, 2006 | 12:39 PM
chuckster's Avatar
chuckster
Have a good one,
Mike
Got Excellent instructions with pictures on how to add the remote bleeder without tearing out the Torque tube!!!
Old Jun 12, 2006 | 12:42 PM
rws.1's Avatar
rws.1
Glad to know that I'm not alone...
Old Jun 12, 2006 | 12:54 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Mr. Murphy
I just finished a head/cam swap yesterday. It seems that I have an oil leak at the balancer and very low oil pressure.
At least it sounded great when I started it!
Bob K.
Old Jun 12, 2006 | 06:42 PM
rww72's Avatar
rww72
Old Jun 12, 2006 | 06:59 PM
Bounty's Avatar
Bounty
Bob K.
More than likely it's the crank seal....
Old Jun 13, 2006 | 12:01 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
When you finish yours, come do mine.
To Simple projects ALWAYS turn to Major Projects!
