For Those Running Iron Blocks...
Old Jun 14, 2006 | 09:02 PM
Dr Chill's Avatar
Dr Chill
Default For Those Running Iron Blocks...
Just curious how much the handling was affected by the added weight. Especially interested if you run track days.
I am trying to decide to base my motor swap on a LS2 or a LQ9 block. Aluminum will cost roughly $1000 more for 65 lbs less weight, but I run a track day every 6 weeks so I think the extra cash probably be worth it.
Old Jun 14, 2006 | 10:14 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
In my 97, Its a non issue.........and I added a 6 point RB & Mini tubs to boot.
Autox, road race and drag races well, very predictable on street rubber.
No R compound..yet
Your oil temp will be higher, I see 235 on an average driving day....of course that is drivivng hard anyway 275 at the track(s). My next mod will be an EOC
Old Jun 14, 2006 | 10:46 PM
tiojames's Avatar
tiojames
Default Iron block
Can't say if the weight would effect the handling enough to make a noticeble difference. You could offset some the weight on the front by moving the battery to the rear, tho.
Old Jun 16, 2006 | 10:12 AM
kromberg's Avatar
kromberg
Removing the AC system makes up for the extra weight of the iron block
Keith
Old Jun 17, 2006 | 12:23 AM
Dr Chill's Avatar
Dr Chill
Decided on LS2
To For Those Running Iron Blocks...
