AC serpentine Belt??
Old Jun 14, 2006 | 09:12 PM
bcarpman's Avatar
bcarpman
Default AC serpentine Belt??
Sorry if this has been covered before, but I searched and didn't find anything.
Maybe I'm missing something obvious, but does anyone have any tips for changing the AC serpentine drive belt on a C5?
The hard AC lines run right on top of the tensioner, so you can't get a long extension on it, and a wrench hits the balancer pulley before the tensioner is loose enough.
Any hints?
Old Jun 14, 2006 | 09:27 PM
BanditDude's Avatar
BanditDude
I put mine on ramps and accessed it from the bottom.
Old Jun 14, 2006 | 10:04 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
YES!!!!, i've swapped motors in these cars, and I can say that belt kicked my azz 2 weeks ago, i usually deal w/ M6/12 cars and had an A4 in the shop, i removed the belt no problem, spent/wasted 20 minutes trying to get it back on, finally moved the car onto the lift and it was a 30 second job
btw, it's the trans cooler lines that run DIRECTLY in front of the a/c tensioner
Old Jun 14, 2006 | 10:18 PM
Kens86's Avatar
Kens86
Did mine from the top. Got it on as best I could leaving partialy off the top of the AC pully and then bumped the engine with the key to hop it on. Maybe not the best way, but it worked.
Old Jun 14, 2006 | 11:14 PM
Silvervettes's Avatar
Silvervettes
St. Jude Donor '07
I justed changed mine for the second time and this time I used a wrench to loosen the tensioner and while holding it I reached down and slipped the belt off the idler pully which is just above tensioner. After backing off on tensioner, I pulled the wrench out of the way and there was enough slack in the belt to slip it on off.
This time I put on a Goodyear Gatorback belt because the other new belt did not solve my squeaks.
Old Jun 15, 2006 | 06:35 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
hmmm..I did mine when I did the main belt from the top..no problems...both belts swapped in under 30 minutes...
Old Jun 15, 2006 | 08:33 AM
bcarpman's Avatar
bcarpman
Default Thanks
Thanks for all the quick help. I'll try it from the bottom tonight. I thought of that, but it didn't look like there was room from there either, but I guess there is.
To AC serpentine Belt??
