Another Gearing Question
Old Jun 16, 2006 | 09:34 PM
Vette'n04's Avatar
Vette'n04
Default Another Gearing Question
I presently have an '04 C5 with A4. My current mods are a Cat Back and air intake. I want more acceleration from a stop and when you lay on the throttle a little while the car is cruising at around 20 or 30 MPH. I don't race the car but mainly use it for cruising around town and some highway. I DON'T want to affect drivability or gas mileage appreciably. My car has 3.15's now. I am thinking about 3.73's or 3.90's. Which do you think will give me the best ALL AROUND "feel" I am looking for. Other than a good tune after the gearing, I'm really not planning to do too many more extensive mods....I hope!! Thanks in advance for any help you can give me with this.
Old Jun 16, 2006 | 10:14 PM
Real Enthusiast's Avatar
Real Enthusiast
I would say 3.90's based on what most A4 owners say. I don't have an A4 though. You might feel as though you wasted a lot of money for not a lot of feel with 3.73's though.
Old Jun 16, 2006 | 10:18 PM
Greg_E's Avatar
Greg_E
I have a M6 , so I'm not up on the A4 stuff, but from what I've read, unless you plan on changing the torque converter I think 3.42's are all you would want. Check the archives. I'm sure there is plenty of info on the subject. I'm sure the A4 guys will chime in and give you the straight scoop.
Here's some info on the subject.
http://forums.corvetteforum.com/show...rque+converter
Old Jun 16, 2006 | 10:41 PM
yaonttwo's Avatar
yaonttwo
3.42 differential and a mild torque converter (3000/3200) is all you need. It will feel like a totally different car with no change in driviability and only a small reduction in gas mileage, provided you can control your right foot . Total cost $2,000.00+/-.
Old Jun 16, 2006 | 11:53 PM
Vette'n04's Avatar
Vette'n04
Will adding the TC result in ANY lag in acceleration when I step on the accelerator? I want the throttle to have a real crisp response! Thanks!
Old Jun 17, 2006 | 04:30 AM
Mitch C's Avatar
Mitch C
If you want to maintain driveability and decent fuel economy. Keep your 3.15 gears and install a Yank SS3200 T/C. Your cars performance will improve greatly and you will still get the same MPG on the highway.
Old Jun 17, 2006 | 07:55 AM
Blow Torch's Avatar
Blow Torch
This is the combo I'm installing in my wifes DD. It will proably hurt hwy milage by a couple mpg, but can actually increase city mpg (if you can keep your foot out of it) by eliminating the minor "lugging" from the low gears you have now. My 3500 created a small amount of "slippage" that would cause you to feel like you were giving it just a little more gas, but after my head change it went away competely (more torque down low??) I don't think the 3000 will be as noticable. that's why I'm going with it on my wife's car.
By the way, depending on who does your work and where you get your parts it can be cheaper than $2000. My total cost not including fluids is going to be $1400. (Re-tune is free)
Old Jun 17, 2006 | 10:41 AM
Mike Mercury's Avatar
Mike Mercury
yes, but depending on the model converter you purchase, it may be minimal.
3.15 to 3.42 is the smallest rear gear ratio change possible on the C5. You will notice a difference, but it won't be a night/day improvement.
I did just that (3.15 to 3.42 - using the factory converter) but I had unique goals in mind.
here's a video of a girl driving my 2002 just after the 3.42 upgrade:
http://hometheater.home.att.net/ohiogirl1year.mpg
Old Jun 17, 2006 | 10:48 AM
123sugey's Avatar
123sugey
Dig
3:90's will wake it up.
converter also.
when i first started my mods on my car, i had 2:73's and a 3500 converter. i knocked off 7 tenths in the quarter with the converter alone !!
Old Jun 17, 2006 | 12:36 PM
tiojames's Avatar
tiojames
Default gears
Don't go lower than 3:42s if you do a lot of highway driving. I put 3:42s and a 3500 stall in my a4 from 3:15s. Gas milage dropped 3 mpg and the performance increased considerably. I can not tell any difference in drivability. You will gain in performance from low rpms due to the stall.
To Another Gearing Question
