Saty-Up headlight problem please help!
Old Jun 17, 2006 | 03:58 PM
eschantra's Avatar
eschantra
Default Stay-Up headlight problem please help!
One of my headlights blew the other day and took the fuse with it. When I replaced the fuse, the headlight worked fine but they stayed in the up position. I lowered them manually, then hit the switch and they popped up, but don't go back down. Now when I remove the key I hear a chime like I left the lights on, even if they're off. Any suggestions? Headlight module maybe? TIA!!!!!!
Old Jun 23, 2006 | 03:41 PM
eschantra's Avatar
eschantra
Anybody???
Old Jun 23, 2006 | 03:46 PM
rcknusa's Avatar
rcknusa
I wonder if disconnecting the battery cable would reset things? I have no idea what could cause that issue. Good luck.
Old Jun 23, 2006 | 10:49 PM
cruisemon's Avatar
cruisemon
Default check these things
Originally Posted by eschantra
Anybody???
Fuses for the headlights - do both headlights come on? If not, maybe a fuse is shot.
Are both on? May be the turn signal lever. It has a very complex set of micro switches and stuff in it. The Parts Lady down in FL sells this thing for about $120 delivered. The installation is about an 8 hour job and involves starting with removing the console to get to the fasteners holding the other parts of the dash cover in place. You'll need a special steering wheel puller and probably ought to get two sets of the pulling hooks since they can break if the steering wheel is really tight (don't ask). Handle the air bag carefully. The actual lever replacement takes all of 15 minutes at the most.
Charlie
Old Jun 27, 2006 | 05:40 PM
eschantra's Avatar
eschantra
Charlie
I'm pretty sure it's not the lever, both headlights do come on and all of the fuses for both the lights and the motors are okay, it's either gotta be the switch or the control module. I'm thinking its not the switch because when I lower the headlights manually, they stay down despite the chime that sounds like the lights are on, and they don't pop back up until I hit the switch. We'll see I guess, I'm gonna try to find a used headlight module and see what happens......
Old Jun 27, 2006 | 07:19 PM
cruisemon's Avatar
cruisemon
Default I'm thinking its not the switch because when I lower the headlights manually, they st
You are exactly right. My problem was they stayed up all the time (wish I could have that problem
never mind.
I think you're on the right track.
Charlie
To Saty-Up headlight problem please help!
