Wasted Rocker Bearing - How Bad?
Any advise is appreciated....also looking for advise on replacement rockers - running a .581 lift cam and Comp 921 springs....
I'd also try a flex magnet into the oil drain, and see if that produces any of the parts...
You may also begin the teardown with the intake... might get lucky, and find the missing pieces in the lifter galley....
OR! You could just order up a new, 427 long block..
No need for a major engine disassembly. I think there is a TSB on this very issue.Tom
Needle Bearings Found In Oil Pan (Replace Rocker Arms) #02-06-01-029 - (Aug 28, 2002)
Needle Bearings Found in Oil Pan (Replace Rocker Arms)
1998-2002 Chevrolet Camaro, Corvette
1998-2002 Pontiac Firebird
2002 Cadillac Escalade, Escalade EXT
1999-2002 Chevrolet Silverado
2000-2002 Chevrolet Suburban, Tahoe
2002 Chevrolet Avalanche
1999-2002 GMC Sierra
2000-2002 GMC Yukon, Yukon XL
2003 HUMMER H2
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, G, S, U -- RPOs LR4, LM7, LS1, LS6, LQ4, LQ9)
Condition
Some customers may comment or technicians may notice needle bearings being found during an engine oil change. The bearings may be found in either the drain pan used or on the magnetic oil pan drain plug.
Cause
One or more rocker arms may have experienced a bearing failure.
Correction
Inspect all of the rocker arms for bearing retainer cap failure. If one or more defective rocker arms are found, replace all 16 rocker arms. Refer to the Engine Mechanical sub-section in the appropriate Service Manual.
If no condition with the rocker arms is found, refer to the service history for previous rocker arm repair. If previous rocker arm repair was made, then the engine may not have been thoroughly cleaned of loose roller bearings. If no previous rocker arm repair was made, then look for another condition.
Remove the oil pan and clean out any additional bearings found within the oil pan. Refer to the Engine Mechanical sub-section in the appropriate Service Manual.
Install the oil pan. Refer to the Engine Mechanical sub-section in the appropriate Service Manual.
Parts Information
Part Number
Description
Qty
10214664
Rocker Arm
16
12560696
Gasket - Rocker Arm Cover
2
12558760
Gasket - Oil Pan
1
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J0357
Rocker Arm - Replace - Both Banks
Use published labor operation time
J1000
Pan and/or Gasket - Replace
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
at least a new engine is fun....How do I know the damage has not already been done? It came apart and the pieces went somewhere? I did not shut the car down and tow it home. I drove it about 10 miles and started it a couple times to get some feedback on the noise. Lets say I get them all out but a couple by using the suggestions of the Forum Members. Were are they likely to end up and what is the potential damage? Won't my magnetic drain plug and oil filter, catch them??
Shirl Dickey
