High HP C5 cooling problem, need advice
Old Jun 17, 2006 | 11:09 PM
ndirishr1's Avatar
ndirishr1
Default High HP C5 cooling problem, need advice
Here's the problem... a C5 Corvette that has had a heads, cam, supercharger and headers installed. It generates about 650HP at the crank.
At night or cool weather it seems to run at acceptable temperatures. At 88F in heavy stop and go the temp rises to about 250F.
The water pump was changed to a hi flow type and that didn't solve it. On test drive with air off it ran about 230F as soon as the air was turned on it shot up to about 250F,
Could the HP on this have exceeded the radiator capacity?
Do you know what the stock radiator will cover in rough HP?
If this sounds like the problem is there an after market radiator that will provide sufficient additional cooling?
If you have done mods to up your HP to similar numbers have you experienced cooling problems?
Would appreciate comments from those that have high HP C5s/
Thanks!
Old Jun 17, 2006 | 11:19 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default this info may help you....
http://forums.corvetteforum.com/show....php?t=1407754
Old Jun 17, 2006 | 11:27 PM
fdxpilot's Avatar
fdxpilot
Just an opinion, but anything over 450rwhp, and definitely any SC engine should get a better radiator. With your setup, you are way beyond the stock radiator capacity. Try Dewitts, BeCool, A & A, or DRM for hi-capacity C5 radiators
Old Jun 18, 2006 | 01:40 AM
6500RPM's Avatar
6500RPM
I added the BeCool radiator, 160 degree thermostat, tuning, and I run distilled water with two bottles of Redline Water Wetter (no coolant)with my setup that produces around 574HP to the crank and it hangs around 180-195 most of the time and 220 in 100+ weather in traffic. I even run that setup in the winter and it stays around 174-185 all day.
Old Jun 18, 2006 | 07:39 AM
Sportsdude's Avatar
Sportsdude
Old Jun 18, 2006 | 07:46 AM
ndirishr1's Avatar
ndirishr1
Thank you, an interesting post. Does anyone out there know what the stock radiator will support. For others with high HP have you had to add cooling?
Old Jun 18, 2006 | 10:06 AM
vetterdstr's Avatar
vetterdstr
I have a Be Cool radiator on my car.
Old Jun 18, 2006 | 10:24 AM
ndirishr1's Avatar
ndirishr1
What HP do you have and did you have cooling problems or was this preventive?
Old Jun 18, 2006 | 02:08 PM
vetterdstr's Avatar
vetterdstr
696 RWHP, Cooling problems with the relocation of the radiator and add to that a hot intercooler in the front, it was time to install everything I could to cool down the entire combination.
Old Jun 18, 2006 | 02:59 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I put in the DeWitt's when I went to a blower as South Texas is not so kind to us in the Summer. Last week I had my car out in stop and go traffice and saw about 210 with the AC on and then I took it for a blast on the highway and temps back in the 190's. I also modified my A&A setup like Andy is doing on his new kits make a gap between the intercooler and AC setup. I also put on the LG screen in place of the license plate, but this is for open road driving and will not help much when you are in stop and go traffic, and it looks good to boot even though it has a big Corvette tax on it
Old Jun 18, 2006 | 07:57 PM
ndirishr1's Avatar
ndirishr1
Thanks, I'll check those out!
Old Aug 22, 2006 | 06:02 PM
Laguna Blu's Avatar
Laguna Blu
How'd you make out? I just ordered a DeWitts to keep my "soon to be blown" motor cool.
To High HP C5 cooling problem, need advice
