Stock 'H' Pipe vs 'X' Pipe??
My stock exhaust system (except for the Z06 Exhaust after the flange) has a pipe connecting each side to one another just after the cats ('H' Pipe). Whate is the difference between that and an 'X' Pipe?? Your help would be appreciated!
[Modified by l2vette, 12:37 PM 8/29/2001]
Plus the exhaust sounds deeper. It's a nice mod if you've already done everything else!
Tim
See pics of my NO cat exhaust install with x-pipe and h-pipe on my home page.
Automakers and performance enthusiasts have been installing balance tubes in dual exhaust systems for years. Tests have shown that balancing the backpressure between the independent exhaust branches increases power and reduces resonance. When Chevrolet introduced the C5 Corvette they installed a simple "H"-pipe balance tube. It was roughly two inches in diameter and provided adequate flow between the 2 1/2-inch catalytic converter pipes.
Factory System
For reasons unknown, a running change was made to the "H"-pipe sometime in model year '97. The change resulted in using a smaller connecting passage of approximately 5/8-inches, thus rendering the "H"-pipe ineffective. From that change forward, C5's have had the smaller balance connection that contributes to a popping exhaust sound on deceleration and a gurgling, or "motorboat" sound at idle.
From a pure performance standpoint the "H"-pipe has some shortcomings. It is fairly restrictive because it is placed 90-degrees to the path of exhaust flow and any crossover gases must turn a 90-degree corner. For several years performance enthusiasts have been upgrading their dual exhaust systems with a more advanced setup with the crossover, or X-style.
A x-pipe added to an aftermarket exhaust on 98/99/00 will smooth your idle to more of a fan than a pump, knock off about 10% of your WOT sound and reduce the popping and gurgling on decel. You will also pick up a few ponies.
On the 97's an '01s it seems to have less of an effect on sound because of the larger opening the stock piece has to start with.
If you get a chance to listen to them back to back, that is, a x-pipe car and a non x-pipe car with the same exhaust, you will see what mean.
The difference on the x-pipes is price, based on materials and length. Welding on the smaller ones (15" x-pipe) is a must. The Corsa Stainless Steel X-pipe requires cutting, but, no welding.
I have the smaller one on my 2000 with Indys and love the sound. Just right for me.
RG
Corsa:
Aluminized pipe:
[Modified by RG in Dallas, 4:32 PM 8/29/2001]
RG, you are on the money regarding comparing sound. At Bloomington Gold, a vendor had two vettes both w/ corsa indy exhaust, but one also had the x-pipe. Very distinct difference in sound - one not necessarily better or worse than the other, just very different.
I would still go x-pipe if I had a '01, because I like it better. Doesn't mean the next guy will, but, I do. If I want it a little louder and thicker, I'd add headers. If I added head and cam to a car, along with headers, I'd go Route 66 from B&B..MATTG on the Forum here went that route(no pun intened, but, I'll take it), it sounds deep and bassy, without a 'scalding' sound. X-pipe would be in there for sure no matter, for me.
When MATTG didn't have head/cam, he had Corsas on his '97. They sound different than mine. We met in Carlisle last year and I rode with him most of the time and noticed the sound was a little different. I thouhgt he HAD an x-pipe, but he didn't. We knew the h-pipe holes were different inside and the light went on to both of us, about the reason for the differences in his sound versus my 2000, with the same Corsa Indys.
Good sound, even GREAT sound is certainly in the eye of the beholder. Just like Music.
RG
Jerry
I have a catback Borla system with a resonator about where the x pipe would be. Does this mean that I would have to special fabricate a crossover, or can I use the small x pipe?
Herb
In the interest of not misinforming you with a guess, I would need a pic. I could give you a better answer to your question that way. The aluminized one is right about 15" long.
RG
:D
I had Corsa Indy and stock X-Pipe and loved the sound. Then I added the Bazzini X-Pipe and it quieted and deepened the sound a fair bit. It was evident that the Bazzini X-Pipe was doing what it was supposed to flow undisturbed air. I can't say how good the Corsa X Pipe is, but I am sure it nearly as good as Bazzini. Corsa might flow a hair less, BUT that might give the car a few more FT lbs of Trq. as some time a bit of back pressure is known to do. I did not dyno both.
I would be interested in any one who took the time to do dyno Stock H Pipe Vs. Bazzini X-Pipe Vs. Corsa's X-Pipe. (Anyone do that?)
I doubt anyone would waste money installing both and dyno'ing both but if anyone has as tests that would be very interesting to see the results.
Thanks everyone for sharing info, I like this CorvetteForum very much, Many Thanks to a few special one C4C5 Tech, All info always appreciated. :seeya :chevy :spam
