Brake Squeak
Old Jun 19, 2006 | 01:49 PM
FabHgirl's Avatar
FabHgirl
1st Gear
Default Brake Squeak
Recently purchased 03 convretible with 6,500 miles. Our dealership is confounded by a rear break squeak at low speeds. They have replaced pads and there is no visible rotor problems.
Any suggestions or comments?
Old Jun 19, 2006 | 02:05 PM
fixvet's Avatar
fixvet
Do the pads have a thin pad cover on the outside of the pad? I had a squeal on a front pad that was just one end of the thin pad cover slightly touching the rotor. I discovered it after just sitting on a stool by the car and slowly turning the rotor and looking and watching for anything unusual. I finally saw the problem when looking straight down into the area with a flashlight where the pads and calipers engage the rotor. I took the pad cover off and no more noise. The pad is cosmetic.
Good luck!
Old Jun 19, 2006 | 04:40 PM
Dirty Howie's Avatar
Dirty Howie
Good luck!
Those thin pad covers are to reduce squeal
I just replaced pads and left a couple of them off and now it squeals like a stuck pig
DH
Old Jun 19, 2006 | 04:49 PM
fixvet's Avatar
fixvet
Hey Howie......those pad covers don't seem to work for me on my ceramic pads. Who knows, eh?? I hate brake noises!
Going to Andy's Sat? I'm riding up Friday with my buddy "Roho" in his Z car.
See you there.
D
Old Jun 19, 2006 | 05:10 PM
djengr's Avatar
djengr
How is the Parking brake system. Just a wag, could it be comming from the drum brakes which is part of the parking brake system?
Old Jun 19, 2006 | 06:14 PM
ALLEGRO's Avatar
ALLEGRO
Before you go tearing into the thing try this:
take her for a drive, and from a moderate speed, bring her to a quick stop. Do this a couple of times to put some real heat into the brakes and then see if they squeek.
This makes mine quiet EVERY TIME
Old Jun 19, 2006 | 06:22 PM
Dirty Howie
See you there.
D
Dennis
I'll see all you down south SCMR guys there
DH
To Brake Squeak
