The grond has not seen a boost psi it did not like and that is why EG is going for the forged setup so he can be in the 14-16 lbs and have lots of fun. Oh anywhere between 6-8 with some alky and you should be fine and no more than 16 degrees of timing to stay conservative and see if you can live with that compression for sometime
