I need help!!!
Old Jun 20, 2006 | 12:26 AM
Manolo's Avatar
Manolo
Default I need help!!!
I need to remove the passenger side actuator from the hvac system on my 2000 C5, I did a search but no luck.I tried looking for the actuator but I can't get to it or even find it. Can anyone that owns service manuals help me out or scan some pics and email them to me???I'm going on a trip from Kentucky to Kansas in mid July and I don't want my wife to burn up,I'd appreciate any help thanks!
p.s. I already tried pulling all the fuses, disconnecting the battery and recharging the freon, NO luck.
Old Jun 20, 2006 | 05:57 AM
Manolo's Avatar
Manolo
come on guys!!!
Old Jun 20, 2006 | 05:58 AM
Manolo's Avatar
Manolo
come on guys!!!
Old Jun 20, 2006 | 11:54 AM
Manolo's Avatar
Manolo
Someone has to know SOMETHING!!!
Old Jun 20, 2006 | 03:50 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Hope this helps you out. It is from the GM Service Information site.
Temperature Actuator Replacement (RH)
Removal Procedure
Remove the front floor kick-up panel. Refer to Kick-Up Panel Replacement - Front Floor in Interior Trim.
Remove the cover from the IP electrical center.
Remove the HVAC CON (HVAC controls) MiniFuse® #27 from the IP electrical center.
Remove the IP upper trim pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper in Instrument Panel, Gauges and Console.
Disconnect the RH side window defogger outlet duct - lower from the windshield defroster duct, then reposition the side window defogger outlet duct forward.
Remove the defroster valve vacuum actuator. Refer to Defroster Actuator Replacement in Manual system or Defroster Actuator Replacement in Automatic system.
Remove the I/P lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - Instrument Panel (I/P) Lower in Instrument Panel, Gauges and Console.
Remove the lower half of the RH floor air outlet duct. Using a flat bladed screwdriver or similar tool, release the retaining tabs, then remove the lower duct.
Remove the floor air outlet duct retaining screws.
Reposition the floor air outlet duct downward to better access the RH temperature valve electric actuator.
Disconnect the electrical connector from the RH temperature valve electric actuator.
Remove the two screws retaining the RH temperature valve electric actuator.
Remove the electric actuator.
Installation Procedure
Position the RH temperature valve electric actuator, then align the slots in the electric actuator driver to the flats on the RH temperature valve shaft.
Slide the electric actuator onto the shaft, while aligning the actuator locating hole to the forward alignment pin on the HVAC module case. The actuator driver should completely seat onto the temperature valve shaft and the actuator mounting holes should be flush with the mounting bosses on the HVAC module case.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the two RH temperature valve electric actuator retaining screws.
Tighten
Tighten the RH temperature valve electric actuator retaining screws to 1.5 N·m (13 lb in).
Connect the electrical connector to the electric actuator.
Position the floor air outlet duct to the HVAC module case.
Install the floor air outlet duct retaining screws.
Tighten
Tighten the floor air outlet duct retaining screws to 1.6 N·m (14 lb in).
Install the lower half of the RH floor air outlet duct. Align the retaining tabs and snap into place.
Install the IP lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - Instrument Panel (I/P) Lower in Instrument Panel, Gauges and Console.
Install the defroster valve vacuum actuator. Refer to Defroster Actuator Replacement .
Position and connect the RH side window defogger outlet duct - lower to the windshield defroster duct.
Install the I/P upper trim pad. Refer to Trim Pad Replacement - Instrument Panel (I/P) Upper in Instrument Panel, Gauges and Console.
Install the HVAC CON (HVAC controls) MiniFuse® #27 to the I/P electrical center.
Install the cover to the IP electrical center.
Install the front floor kick-up panel. Refer to Kick-Up Panel Replacement - Front Floor in Interior Trim.
Document ID# 615629
2000 Chevrolet Corvette
Old Jun 20, 2006 | 04:21 PM
Manolo's Avatar
Manolo
THANKS RichieRichZ06 !!!! I'm going to try this tonight. I know I'm asking for alot but is there any way possible that you could get me some pics of the procedure and a part #???
Old Jun 20, 2006 | 05:04 PM
RichieRichZ06
St. Jude Donor '08
Part # is 89018365. It is the same for the right and left sides. Unfortunately, the info that I am giving you is off the web and I don't have any other way to send them to you. If you need anything else please feel free to ask. RICH
Old Jun 20, 2006 | 05:53 PM
Manolo's Avatar
Manolo
sent you a PM
To I need help!!!
