Biggest TB for LS6 intake
Old Jun 21, 2006 | 01:31 AM
N0TDADYS_98's Avatar
N0TDADYS_98
Default Biggest TB for LS6 intake
what is the biggest TB i can put on an LS6 intake... i've seen ported bodies that advertise (ecklers) to flow 1030. does this sound right?
Old Jun 21, 2006 | 11:07 AM
N0TDADYS_98
well crap.. I better bump this before it falls off..
Does anyone know what my stock 98 t/b flow & how big it is?
Old Jun 21, 2006 | 01:30 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
I don't have the flow numbers at hand but the stock size 97 to 04 is 75 mm. The largest you can go with the LS6 intake without modifying it is 80 mm.
TPIS makes a oval 75mm X 90mm (width). You have to send them your intake for re-work, they replace the snout with a new piece. Flow is 1200 according to the TPIS web site. I have seen a test showing about 10 rwhp inc over 5000 rpm compared to the stock 75 (on a cammed LS1)
Check out TPIS web site http://www.tpis.com/index.php?module=default
Hope this helps.
Old Jun 21, 2006 | 05:38 PM
Gordy M's Avatar
Gordy M
If you are running a stock engine, the larger TB will not add any HP. On a boosted or juiced engine it will be of value and also a large cube H&C engine. Up to 2000 the MAF was 75mm and the TB was 78mm. In 2001 they went to the LS6 intake for the corvette and 85mm MAF. At 405 hp the TB was still not a restriction. It will make about 525-550 hp, if you are making more, then a change will be needed
To Biggest TB for LS6 intake
