what can cause code P0174 lean bank 2?
Old Jun 21, 2006 | 08:46 AM
4THTOY's Avatar
4THTOY
Default what can cause code P0174 lean bank 2?
Any ideas what I should look for to correct this? Seems to be a lean condition in one side only
Old Jun 21, 2006 | 09:20 AM
Ranger's Avatar
Ranger
Do you have an aftermarket air intake on the car?
Ranger
Old Jun 21, 2006 | 01:04 PM
nwc6's Avatar
nwc6
I had a 99 Grand Prix GTP give the same code, intermittently, accompanied with a rough idle. It was the intake manifold gaskets dried out and cracked on one bank. I found mine by hooking up the Predator tuner for the ‘vette and reading the O2 sensor. When I hit the spot with the soapy water the O2 numbers dropped to normal. You can try spraying the intake gaskets with carb cleaner. If you have a leak, idle speed will increase.
To what can cause code P0174 lean bank 2?
