Can someone please tell me what kind of Intake I have? I have a 2000 Vette that I would like to upgrade to one of the better stock or aftermarket intakes. I would rather get something that needs little to no mods done to it. I am not sure if I have a LS1 or LS2. I hear the LS6 is better?
I’m sure someone out there can answer this. This forum always has good guys with the right answers.
Sorry if this is a little elementary of a question.
you have the LS1, in 2001 Chevy started using the LS6's on all vettes, the change is easy, however on an otherwise stock engine you will see a very small difference, and then only at the upper RPM's. Do you have the stock airfilter? If so i would change this right away, you will see a difference while spending less money
Unless you are changing the heads, cam and putting on some headers I would not change the intake
Hi David, also, check the SouthWest Section of the Forum for Get-To-Gethers around DFW and talk to some of the Vette Guys. They'll give you some good info.
dont bother changing....spend the money on something else...u wont see any gains...i had the old ls1 intake and swapped to the ls6 intake and a mostly bolt on setup and gained almost nothing maybe 5 or 7hp if that
