alignment question with aftermarket wheels
Old Jun 21, 2006 | 10:16 PM
wantmyc5's Avatar
wantmyc5
Default alignment question with aftermarket wheels
Can anyone chime in on whether you need to align a Vette to different specs than stock or Z06 specs if you change you wheel size? I put a set of SSR GT3's on my coupe and wanted to get a wheel alignment and wasn't sure if I put it in factory spec if it would be correct or not.
Old Jun 22, 2006 | 12:37 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
What size tires? It is a good idea if you have a different diameter.
Old Jun 22, 2006 | 01:31 AM
wamara's Avatar
wamara
Cruise-In II Veteran
I can possibly see this with a different width tire, but what would the tire's diameter have to do with it?
Old Jun 22, 2006 | 09:54 AM
wantmyc5's Avatar
wantmyc5
I have 18's up front and 19's in the rear. The rears are 11", not sure on the fronts. I'll post the tire sizes after I get home later.
To alignment question with aftermarket wheels
