Check engine light P1416 and P0161
My question is what words of wisdom do you folks have so when I take it to the dealers that 1) it gets covered by warranty and 2) they don't try to tell me I need something more than is necessary.
While I checked the DTC codes I also have U1160H and U1000H and U1064H. Any advise on those codes? I read the code descriptions from the links other have posted, but it doesn't explain what the actual problems are.
P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P1416 AIR System Bank 2
U1064 Loss of Communications with BCM
U1160 Loss of Communications with LDCM
U1000 - appears to general RFA (Remote Function Actuation)
Any advise would be appreciated.
2001 Pewter Coupe
