A4 tranny and diff. fluid life.
Old Aug 30, 2001 | 12:41 AM
Cosmo Kramer's Avatar
Cosmo Kramer
Default A4 tranny and diff. fluid life.
Forget what the owners' manual says. What's you opnion on the A4 tranny fluid and differiential (sp?) fluid life. My C5 has 25K on it and the dealer says it's time to change the fluid (never been done before.) Thanks.
Old Aug 30, 2001 | 12:53 AM
Duck916's Avatar
Duck916
Default Re: A4 tranny and diff. fluid life. (98-C5)
Unless you've been racing the car, I'd follow the schedule in the manual. Remember that most dealers want to get a few easy bucks by providing unnecessary maintenance work. The dealer I bought my car from gave me a brochure listing all sorts of unscheduled maintenance to bring the car in for, including tire rotation! (To be fair, it wasn't a Corvette-specific brochure.)
Old Aug 30, 2001 | 12:59 AM
Cosmo Kramer
Default Re: A4 tranny and diff. fluid life. (Duck916)
Duck916...........Good point. However, dosen't the owners' manual say that you can go something like 15K miles between oil changes? NOT!!!!
Old Aug 30, 2001 | 02:18 AM
Duck916's Avatar
Duck916
Ya got me there, 98-C5. Though there have been a few debates about oil life here, I can't bring myself to go past 5000 miles. Nope, can't do it!
Old Aug 30, 2001 | 10:15 AM
Chopper Larry's Avatar
Chopper Larry
The GM stated service interval in the manual is 100,000; If I were using it harder I'd do it every 15,000. I'm gonna do mine at 50K, which within the next month or so for me; I'll post the condition of the old fluid.
Old Aug 30, 2001 | 12:51 PM
Kenny94945's Avatar
Kenny94945
Hi,
The C4 had a 15K trans fluid change as a recomendation.
On my C5, I speeded this schedule up, but my .02 is change every 15K as a fellow co-member above also wrote.
Here is some other data:
1 - there are two types of transmission filter...deep pan and short pan. Be aware.
2 - There is a replacement O-ring in the filter kit. A proper tool for the removal of the old one makes life easy. See the service manual.
Also, I first changed my filter and oil at 9K and the oil was brown. Tooks 5 quarts.
Next change, was at 20K and I had wrong filter. Pan gasket was reused. Some metal shavings and brown oil noted.
Last change was at 22K (had correct filter), and oil looked red and good. However, I noted brown/ black clutch disk residue after this short time.
Always shifts/feels better after an oil change by the way.
Around my area the dealer charges around $100. to do a trans oil flush. You should go for it and then go onto a 15K schedule. Again my 02.
Thanks given to all on this forum.
Kenny
To A4 tranny and diff. fluid life.
