Traction control question
Old Jun 22, 2006 | 03:47 AM
Just say n2o's Avatar
Just say n2o
Default Traction control question
When the traction control activates does it cut fuel at all or does it simpply close the throttle blade? The reason I ask is I am just about finished with my nitrous install and I am not really all about sweeping my engine off the pavement because I gave it too much right foot.
Old Jun 22, 2006 | 09:31 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I think it only applys the brakes to the slipping wheel and has nothing to do with the engine.
Old Jun 22, 2006 | 12:27 PM
rickkym's Avatar
rickkym
I don't know what Vintage is driving but my 97 sure as heck cuts throttle! I hit it all the time autocrossing and at the track when I forget to turn it off. I think it just closes the throttle blade but the car stumbles bad enough that a fuel cut might be there too.
**SOME** cars have competition mode which is set by holding the traction button for 5-10 seconds with the car stopped and you'll see the DIC acknowledge this. In this mode only the brakes are modulated.
Does anyone know which models/years have competition mode? Is it only on the Z06's??
Old Jun 22, 2006 | 04:34 PM
87SAM's Avatar
87SAM
I can't remember when Active Handling came out, 99 maybe??? My 2000 FRC has it.
Old Jun 22, 2006 | 04:47 PM
Skunkworks's Avatar
Skunkworks
In a nutshell yes… there are several modules that interface to TB controller. PCM commands a throttle position via communications bus, the traction control outputs a pulse width modulated signal (PWM) this is then somehow summed or something similar and drives TB motor. TPS signal is then read by PCM and TB controller.
Mike
Old Jun 22, 2006 | 04:55 PM
Bill Dearborn's Avatar
Bill Dearborn
TC uses both brake and throttle/spark control. At lower speeds it tends to use the brakes first (like a fancy antispin axle) with power reduction if that doesn't work. At higher speeds brake application isn't fast enough so they use power reduction.
Bill
Old Jun 23, 2006 | 09:10 AM
printmanjackson
Bill
This explains why I have never seen it back off the throttle. I have only seen it come on at low speeds. good info
Old Jun 23, 2006 | 03:40 PM
BltByKrmn's Avatar
BltByKrmn
Mine cuts throttle or fuel all the time coming out of corners.
Old Jun 24, 2006 | 09:59 AM
Rogue Leader's Avatar
Rogue Leader
St. Jude Donor '08
So the suggestion here would be use competition mode or off mode all the time. There is a plug in box out there that can make it default to either one every time you start the car.
Old Jun 25, 2006 | 07:58 AM
debmwb's Avatar
debmwb
yes... http://www.laptrax.com/Products.asp
I certainly would not default it to OFF. Using COMP mode is the safer way to go.
To Traction control question
