Not hard at all.
Remove air cleaner assembly
Remove radiator upper support
Remove screws from lower front edge of housing
Disconnect hood light/air temp sensor plug(s) (if equipped)
From the front, grab both sides of shroud and smartly yank forward. This releases the push pin (aka Christmas Tree) retainers.
Remove and re-install the drivers side push pin before re-installing the shroud.
The rest is just the opposite.
Jump in there. You can do it.
HTH,
Robert
