Okay yesterday my A/C stopped working it only flashes, I ckecked the relays, fuses and Batt. now today the steering wheel is locked up and the alarm does not work. It must be elec.???????? I saw someone had a build up of water from there A/C... Please help
Ok, so you've checked the battery - looks good and running about 13.4 when its running? No codes being thrown and no signs of moisture around the interior fuse box, or anywhere else. The last thing you were working on was cleaning the grounds.
I think we may want to get this post moved over to C5 tech - we need someone to help you understand what is common between these symptoms. Maybe there is a power connector somewhere that both the column lock and the AC go through that's loose...
Hello, I installed a new battery yesterday just to be on the safe side. The steering seems to be okay but the A/C is still out. I'm going to get the freon checked on Mon.
