How to install new stainless braid brake lines?
Old Aug 30, 2001 | 12:05 PM
DUKE's Avatar
DUKE
Default How to install new stainless braid brake lines?
Have ordered some new stainless braided brake lines and wanted to see if I could install myself. What is the proceedure and how hard is this install and is it best to take it to a trusted installer? Thanks for the info.
Old Aug 30, 2001 | 09:51 PM
Nimrod's Avatar
Nimrod
From: Willow Glen, California......................"But... Chunks is our dog!"
Default Re: How to install new stainless braid brake lines? (DUKE)
Duke,
While I haven't done this mod, I would expect it to be a fairly straightforward remove and replace job. Once the new lines are installed, you must bleed all of the air from the system. Check with a repair manual or a (Vette) knowledgeable buddy for the proper bleeding procedure. Good luck and let us know how it works out.
Old Aug 30, 2001 | 09:54 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
SSBL's are one of the best things you can do for your C5 brake system! What type of lines did you get? Some types of lines cause Code problems.. :( I know this first hand... Dont install them until you post to this thread.
vetterdstr
Old Aug 30, 2001 | 11:39 PM
DUKE's Avatar
DUKE
Default Re: How to install new stainless braid brake lines? (vetterdstr)
Vetterdste,
I got these lines from the GP purchase on the Corvette Mall here, I would hope they would not sell any that was not a match for the oem set. Which ones did you install that gave problems? :confused:
Old Aug 30, 2001 | 11:51 PM
DUKE's Avatar
DUKE
Default Re: How to install new stainless braid brake lines? (z06bliss)
Rob,...I ain't takin no pictures...that's the ole brake fluid in the face and camera trick :lol: Saw that on "Get Smart" tv program one night. You goin have to get up a lot earlier to pull one like that. Are you serious? You want to see how they look installed? I was just getting them for function and durability...never thought of showing them suckers off. :jester
Old Aug 31, 2001 | 01:09 AM
Mike Schriber's Avatar
Mike Schriber
Hi Earl! I just e-mailed you a draft copy of our CorvetteDreams.com installation article on DRM stainless steel brake lines, It should be the same for the ones you bought.
Good luck!
Mike
Old Aug 31, 2001 | 01:29 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: How to install new stainless braid brake lines? (Mike Schriber)
I'm doing my lines this week end. I've heard that if you demagnatize the lines there is less chance to get errors from the wheel sensors.
Old Aug 31, 2001 | 01:57 AM
vetterdstr's Avatar
vetterdstr
I had the Russell lines and I doubt that running a Magnet over it will keep it from not grounding correctly. I have the Goodridge now and I have no problems with them.
vetterdstr
Old Aug 31, 2001 | 02:08 AM
Nimrod's Avatar
Nimrod
:D Good one. Thanks for the laugh! :D
Old Aug 31, 2001 | 07:44 PM
Bandit400's Avatar
Bandit400
In terms of the stainless steel lines causing problems with the wheel sensors, I spoke with the GM Engineering at Carlisle responsible for Chassis systems(ie. ABS/AH/TC) about the brake mods on my car. He indicated the setup I had would cause no problems with the brake systems. In fact he actually recommended the stainless lines as good brake mod for improved performance. What he did not recommend is the brake bias spring and using different pad compounds on the front than what is on the rear. Hope this helps. :yesnod:
Bandit400
To How to install new stainless braid brake lines?
