voltage regulator/altenator change
Old Jun 24, 2006 | 01:11 PM
pawngod's Avatar
pawngod
Default voltage regulator/altenator change
i wanna know can the altenator regulator be changed w/o changing altenator...my voltage is all over the place low to high ...or would i be better of changing entire unit
Old Jun 24, 2006 | 02:29 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Voltage Regulator
You can change the regulator only. I just had mine relpaced at a local auto electrical shop. It dropped off the table while I was doing my Heads/Cam.
They charged $100.00 to replace the regulator and swap the pulley (ASP underdrive). It looked like there are 3 wires that need to be soldered, other wise it looked like an easy swap.
Bob K.
