pass.side window problem
Old Jun 25, 2006 | 09:34 AM
maddman's Avatar
maddman
Default pass.side window problem
My pass side window gets stuck in the down position every once in a while what could be causing this and what is the cure.When this occurs pass.or drivers side buttons do nothing slaming the door works and messing with the buttons for a few minutes has worked this has only happened a few times I would like to fix it before im stuck with it in the down position in the rain most likely
