hud not working after bezel install
Old Jun 26, 2006 | 06:29 AM
mjohnson68's Avatar
mjohnson68
Default hud not working after bezel install
HELP..... Bill if you can shed some light on this one that would be great.... I installed the bezel set last night and after doing so my hud quit working..... I checked all of the connections again but did not find anything unlplugged.
The bezels look GREAT....but now my hud is dead.....
Old Jun 26, 2006 | 09:27 AM
SpeedyZ's Avatar
SpeedyZ
Make sure the white plug is all the way down in the top of the cluster. Check it, and check it again! It has got me a few times! It looks like it is in but one side won't be pushed all the way down, HUD will appear completely dead.
If the 11 pin cable between the HUD switch panel and back of cluster is not connected good you may get the same thing, the HUD will really be working but it the switch is unplugged it will be dimmed all the way to off so you can't see it.
My bet is on the top plug though, it is easy to not get seated.
Good luck
Old Jun 26, 2006 | 10:12 AM
Sully1882's Avatar
Sully1882
yeah almost for sure bet that the top plug for the HUD hookup is what is the problem.... firmly but gently make sure it is completely seated. It can easily be bent, the pins that is, and you just need to make sure it is all in there the right way all the way. Plus when the gauge cluster is being re-installed the wire can get pulled out or dislodged easily.
HTH Thomas
Old Jun 26, 2006 | 11:40 AM
mjohnson68's Avatar
mjohnson68
I did check that top connector a couple times and even disconnected and reconnected to make sure...... Not sure what happened, but could I have damaged the HUD by disconnecting it?
On a side note.....will a z06 cluster work in a c5? Are they plug and play? I like the angled numbers in the z06 cluster.....
Old Jun 26, 2006 | 12:43 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
I'm sure you have checked this... Is HUD turned on and the light adjustment turned up high enough to see it?
Old Jun 26, 2006 | 12:48 PM
Sully1882's Avatar
Sully1882
Default Z06 cluster
yes the clusters are all pretty much plug and play... it's just all the PITA of removing the interior so you can plug and play that sucks....
Old Jun 26, 2006 | 12:57 PM
ALLEGRO's Avatar
ALLEGRO
HTH Thomas
Got me TWICE
Old Jun 26, 2006 | 01:53 PM
mjohnson68's Avatar
mjohnson68
Yea, I have played with all of the switches thinking that it was just turned down but no luck there.
I guess I will have to check the wiring again and see if there is something I missed.
Old Jun 26, 2006 | 02:49 PM
SpeedyZ's Avatar
SpeedyZ
If you can get a voltmeter in there you can check the voltage on that top plug. Just probe the back side right beside the wire and it will make contact. With the plug plugged in you should get: The first pin/wire from the right is ground, the second from right should have 12VDC, the third from the right is (the best I remember) the dimmer control, it should read 5VDC on dim and 0VDC on bright. On the left side of the plug the first wire, third hole in connector (first two unused) should have 5VDC and should go to 0VDC when you press the down button, the second wire is the up control and should read 5VDC and go to 0VDC when you press the up button. The three left over is data and will read either 5VDC or 0VDC and may be changing.
I'm still betting on that top plug, I never get the right side down far enough. Check the voltage and let us know.
Also try the to move the HUD up and down and look down in through the windshield and see if the mirror moves or not.
Be sure the key is on for all the above test!
Z06 cluster should work fine. You shouldn't damage the HUD disconnecting it, unless you broke a wire in the plug. I would make sure the key is off first though. Even better unhook the battery.
Old Jun 26, 2006 | 05:31 PM
mjohnson68's Avatar
mjohnson68
will do thanks speedy......
I will keep you all informed as to what I find out.
To hud not working after bezel install
