Meaning of error codes(fast reply please)
Old Aug 30, 2001 | 10:48 PM
01Z06's Avatar
01Z06
Default Meaning of error codes(fast reply please)
Does anyone know the interpation of the following codes on my DIC(after running diagnostics)
1) B2252-H key cylinder switch fault
2) U1064-H Loss of com with DCM
Car seems to run fine, but gave me a "charge system fault" message on the DIC and voltage is running a little lower than usual(12.9 to 13.2) as opposed to the usual 13.8 or so. Do I need to take the car right to the dealer ASAP, or can it wait till Tuesday? (Monday is a holiday) I don't want to be without the car over this holiday weekend, but I don't want to get stuck in the middle of Bumf-ck Egypt either! Any input would be greatly appreciated! :confused: :eek:
Old Aug 31, 2001 | 12:01 AM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: Meaning of error codes(fast reply please) (01Z06)
Hi there,
The 2252 is simply telling you that your drivers side key switch is not giving the correct signal to the DCM.
It is not going to give you a drivability problem, just a BCM code, and it will ahve to be diagnosed by your technician.
Nothing major here, the other code, could be considered normal.
Best to you, c4c5
Old Aug 31, 2001 | 12:03 AM
c4c5specialist
Default Re: Meaning of error codes(fast reply please) (c4c5specialist)
Sorry, mistake there, as the other code is telling you that something is wrong with the DCM. So my guess is that the DCM is dropping out, causing the 2252 code.
Your tech can confirm this with a Tech2, sorry about the mistake, c4c5
To Meaning of error codes(fast reply please)
