Just seeing if anybody has ever seen this one and how bad do you think the damage is. I was driving the other day and the check engine light came on and I lost almost all power, I opened the hood and when looking from the front of the car, the far left spark plug was dangling from the ignition wire. I let the car cool down and tried to put the plug back in but it never will tighten. It is theaded enough to no be able to just pull out but it is just kinda hanging there. I bought a new spark plug hoping it was just the old plug which was stripped but it is doing the same thing. Is this something which you all think could be rethreaded?
Sorry to say I was the last one to change the plugs so I it was my fault, that was about a year ago.. So if I replaced the headers and upgraded them would that solve this issue or is it in the engine block. don't know the internals of the engine that well.
the spark plug sits in a hole in the head which sits on top of the engine block.
it's odd that out of nowhere it would fail like that .. are you sure nobody has been messing with your car?
there are two options, one pull the head, have it re-threaded or two replace the head altogether .. might be a nice time to change out to some more flowing heads
but based on your initial response .. my suggestion would be to take it to a trusted mechanic .. best of luck
Thanks for any reply
The threads for that plug are damaged, replaceing the header will not do anything for this. You have to repair the threads, either by drilling an oversize hole, retapping and using a different plug in that hole OR, use a Helicoil which works by drilling and tapping oversize (as above)then putting in an threaded insert with the EXACT thread (count and pitch) as the originals. This is best done with the head off the car but (with access and time) can be done on the car. The trick is keeping the chucks of metal from the drilling and tapping out of the cylinder. I've seen this done several way, but basically the drill/tap has alot of grease on it to catch the chips and you only go a little at a time cleaning the bit often and regreasing.
The original problem is the threads in the Aluminum head were damaged (probably by galling). You can really only chage plugs safely in aluminum heads when things are cold and you have to use antiseize on the plugs before the new ones are installed.
Originally Posted by dougbfresh
........(Snip)
You can heli-coil it, or you can weld it up and re-machine it, or you can just buy another head. LS1 heads are pretty cheap since a lot of people upgrades to better heads. But don't stick a used head on without having a quality machine shop inspect the valves, guides, springs, etc.. I personally would take the head off if you chose to heli-coil, and not try to do it on the car. But your best choice would be to just get another head. I would only attempt a heli-coil if you had a lot of money invested in the head.
ditto the all the above & I whud have the shop check the other plugs too.You can keep yr fingers crossed ,but there could very well be more than one thats failed.Could be both heads have to be removed,if you tell the shop what to do ,thats all they will do.It will be cheaper for them to check it out first....good luck!!
