Tire Sensor Problem
Old Aug 31, 2001 | 05:08 AM
blueszy's Avatar
blueszy
8th Gear
Default Tire Sensor Problem
I just had a large nail removed from my C5's rear tire. The Goodyear service tech advised me that the tire sensor is not accurate; it's off a few pounds. Just wondering, does anyone know how to caliberate the sensors?
Thanks in advance.
Old Aug 31, 2001 | 05:47 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: Tire Sensor Problem (blueszy)
The sensor cannot be calibrated! If everything was done right and the sensor still shows wrong ppressure it has to be changed by a new one. At front left I have the fourth sensor.
But, did he run the car? To show the right pressure the car has to run.
Hope this helps
Frederik
Old Aug 31, 2001 | 11:54 PM
AdrenalineJunkie's Avatar
AdrenalineJunkie
I talked to my mechanic earlier today about a svc tire pressure monitoring system error code.
In the course of the conversation, he commented that the sensors were
supposed to be accurate +/- 2 pounds.
So I guess it depends on how far "off" the sensor is compared to what the guy at Goodyear says he put in it.
AJ
2001 NBM/Blk M6 Coupe
R8C 18 Aug 2001
'02 LS1, CAGSX, Lloyds mats, CAU lettering, rear plate
[Modified by AdrenalineJunkie, 9:54 PM 8/31/2001]
To Tire Sensor Problem
