I Got YANKED BIG TIME!!!!!!
Old Aug 31, 2001 | 07:17 AM
Tom Hall's Avatar
Tom Hall
Default I Got YANKED BIG TIME!!!!!!
I went to the track with my new Yank set up. Hot, Humid and no track Prep(normal for test and tune). I managed to pull off three 10.80s and one 10.90 @ 127 mph. Didn't change anything from the last time out when I was running 11.0s. I'm a happy Camper to get this out of a 346 and stock heads. New times in my Sig. 101 mph in the 1/8 :eek:
Old Aug 31, 2001 | 07:20 AM
TRR's Avatar
TRR
Default Re: I Got YANKED BIG TIME!!!!!! (Tom Hall)
Very nice.
MRR
Old Aug 31, 2001 | 08:42 AM
CRUZMISL's Avatar
CRUZMISL
Default Re: I Got YANKED BIG TIME!!!!!! (MRR2)
Tom,
What is the str of that converter? That is a serious time you are running. Since you have had both PT and Yank maybe you can give us your impressions and end the argument which one is better once and for all
Joe
Old Aug 31, 2001 | 08:59 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: I Got YANKED BIG TIME!!!!!! (CRUZMISL)
Ha, no comparison if you are a serious racer like Tom.
Yank makes 30 different converters, from mild to wild. Tom went with wild, and some serious racers on http://www.ls1.com go even wilder (ie 4400 stalls, etc).
How many converters does Pro Torque make....2?
Get Yanked, or get left in the dust! ;) :smash:
Great times Tom, must feel good to break into the 10s. :cheers:
[Modified by 2000^C5, 7:24 AM 8/31/2001]
Old Aug 31, 2001 | 09:01 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
that's unreal, congrats!!!
Mark
Old Aug 31, 2001 | 09:19 AM
Redvette_22's Avatar
Redvette_22
Good times Tom !!
2000^C5, although you put "how many converters does Yank make...2", I am sure you meant ProTorque. However, if you call ProTorque, just like you have to do with something like this in Yank, you can have anything made you like. They are just as accomidating with stall speeds as Yank, or most other manufacturers for that matter. Just thought you would like to know.
Old Aug 31, 2001 | 09:29 AM
TOBASCO's Avatar
TOBASCO
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
Tom,
Great times! Congrats!
I still show people my BG drags video from the last CI, and I love showing them the front end of your C5 lift, demonstrating the weight transfer issue you helped me understand.
Keep it going!
Old Aug 31, 2001 | 09:33 AM
2000^C5's Avatar
2000^C5
Default Re: I Got YANKED BIG TIME!!!!!! (Red98C5)
Thanks Dennis,
I did not know Pro Torque could make a 4400 stall converter for me with a 3.0 STR if I wanted it.
The reason I did not know this is I have never seen anyone with a PT that has something different than a 2400, or 2900 stall speed.
With Yanks, 3000 and 3500 are the most common for C5s, but for more serious racers (a few on here, and a ton on http://www.ls1.com), the stall speeds and STRs usually increase as the 1/4 mile times get faster.
I am sure other companies are good as well, but the bottom line is that Yank is the most popular among the fastest cars. You can't argue with success.
Look at Tom, he simply switched to the proper converter for his application and easily broke into the 10s in bad track conditions. To me, that's proof enough that Yank is ahead of the competition.
Old Aug 31, 2001 | 09:42 AM
CRUZMISL's Avatar
CRUZMISL
Default Re: I Got YANKED BIG TIME!!!!!! (2000^C5)
Hey I knew that! I just wanted to rub it in :D Yank :smash: the competition. Flame suit is on and ready.
Be :cool:
Joe
Old Aug 31, 2001 | 09:48 AM
DUKE's Avatar
DUKE
Tom....you da man....we are not worthy :yesnod:
Great time.....Smoookin :yesnod:
Old Aug 31, 2001 | 10:30 AM
Austrian Vette's Avatar
Austrian Vette
You catched me!!!!!! :D
Congrats, Tom
and welcome in the 10`!!!!!!! :cheers:
That are the times I thought you can do and on a little better
track and perfect conditions you may see 10,6!!!!!!!!!!!!!
It´s so phantastic!!!!
10,8`s on a stock engine with only a cam!!!!! :eek: :eek: :eek: +NOS
Not much investment to that engine, but great results.
You are the man!
You really have a perfect setup, now.
Don´t forget to video that next time, I must have
a copy!!!!!!! :crazy: :yesnod:
But you know, now we all wanna see you breaking in the 9`s
with new heads!!!!!!! (or at least low 10`s). :D :D :D :D :D :D
Ok, at least I want to see that!! :D
Again, big, big CONGRATS, my friend!!!!!! :cheers:
Michael
[Modified by Austrian Vette, 3:31 PM 8/31/2001]
[Modified by Austrian Vette, 3:33 PM 8/31/2001]
Old Aug 31, 2001 | 11:08 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: I Got YANKED BIG TIME!!!!!! (Austrian Vette)
:cheers: Tom I knew you could do it! Absolutely impressive times with that basically stock engine! :smash: You Da Man! :D No one deserves this more than you! :cheers:
Old Aug 31, 2001 | 11:38 AM
ncvetteman's Avatar
ncvetteman
Impressive....thats got be the fasted time out of a stock headed C5.
Old Aug 31, 2001 | 06:32 PM
Mag Red Monster
Elite Member
Default Re: I Got YANKED BIG TIME!!!!!! (ncvetteman)
:cheers: I believe this one deserves TTT :yesnod:
Old Aug 31, 2001 | 06:49 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Tom.. very impressive! From the pic, you are getting massive front end lift .. great weight transfer. When I spoke with you at the cruise-in, you mentioned that you are disconnecting the sway bar. Have you now disconnected the front spring and/or shocks also? You won't have to get that front end up a whole lot more to get some air under those skinnies!!!
How you doin that????
TOM
Old Aug 31, 2001 | 06:52 PM
kewlbrz's Avatar
kewlbrz
NICE job. Very impressive with stock heads! :crazy:
Old Aug 31, 2001 | 09:39 PM
robsvette's Avatar
robsvette
and you did that with only 3:42's!!! imagine 3:73's!!! :eek:
what do you dyno?
you definitely deserve the corvetteforum trophy!
Old Aug 31, 2001 | 11:10 PM
Tom Hall's Avatar
Tom Hall
Default Re: I Got YANKED BIG TIME!!!!!! (robsvette)
Thats guys, I appreciate the support. I didn't want to start up the Converter war again. Their are a lot of choices out there. I was happy with the Pro Torque, I just wanted to try something different. Also I thought if their were any issues with the new Tranny, having the Yank converter would eliminate at least one problem.(if you know what I mean).
I guess I will have to take the picture out of my signature. I had my front shocks unhooked and now I have custom drag shocks on the car and the front end doesn't come up that high with the shocks hooked up.
I have never Dynoed my car. I do my testing at the track.
I will be heading for BG in the morning and hope to see some of you there again.
Tom
Old Sep 1, 2001 | 12:22 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Incredible times all across the board. MPH is unreal at 127 mph. What shot nitrous are you running in that stage II sete up. THis :cheers: for you brother!
Nitro
[Modified by Nitrovette, 10:23 PM 8/31/2001]
To I Got YANKED BIG TIME!!!!!!
