Driver's side window malfunctioning. Bad motor?
Old Jun 29, 2006 | 02:32 PM
tshaheen's Avatar
tshaheen
Default Driver's side window malfunctioning. Bad motor?
A couple of months ago, my driver's side window started having problems. The window would roll down no problem, but when i tried to roll it up, it would get stuck at the half-way point and wouldn't go up unless i physically 'tugged' up on it while pressing on the 'window up' button. I opened up the door and loosened up the things holding the window just a little (sorry, i don't know exactly what they're called). That fixed the problem for a couple weeks, and then it came back. Since then, it has gradually gotten worse, to the point where now i have to completely pull the window up with my hand.
So i guess i have two questions:
1.) Do you think it's the window motor or something else?
2.) Is there a cheaper place to get them than a chevrolet dealership, because they quoted me 327.87 for the window motor + actuator.
Thanks in advance for your help.
Old Jul 1, 2006 | 10:50 AM
tshaheen's Avatar
tshaheen
*bump* top.
Old Jul 1, 2006 | 11:13 AM
TEXHAWK0's Avatar
TEXHAWK0
If the cable system does not look twisted or damaged, then the problem is most likely in the motor. You might be able to clean the motor and get it to work a while longer.
A friend of mine has bought two complete window actuator assemblies on e-bay from a guy that was removing the glass to build a race car and they work fine. Maybe you can find a good, used actuator assembly if you shop around.
Old Jul 1, 2006 | 12:55 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
your best bet is to pull the door panel and look at the track assembly for visible signs of binding or lack of lubrication. If all looks well you will need to replace the window regulator assembly (motor and track come as one piece).
Old Jul 1, 2006 | 04:26 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
http://www.windowmotor.com/
i got mine from there for about $150 or $175 last year. the motor works very well 0 problems after the install.
To Driver's side window malfunctioning. Bad motor?
