Alignment
Old Jun 30, 2006 | 11:07 AM
N0TDADYS_98's Avatar
N0TDADYS_98
Default Alignment
never done one... or seen one done... is it possible to align my wheels myself? I accidently turned a tie rod a couple of times while removing the steering rack..
Old Aug 20, 2006 | 07:30 PM
vette747's Avatar
vette747
Ok. looking again at some guys who did not got any answers. Yes you can. You just need jack stand, rope and measurement tape.
you can search google for DIY alignment and you will find good info.
Old Aug 20, 2006 | 09:21 PM
rws.1's Avatar
rws.1
My local stealership only charges $39.95 for a front end alignment.... $29.95 2x per year ( spring and fall specials)
At that price I let them do it.
Old Aug 20, 2006 | 09:23 PM
TEXHAWK0's Avatar
TEXHAWK0
If you only turned the tie rod end, and not the alignment cams, you only affected the toe-in. The toe-in is always set last anyway since all other adjustments to caster and camber affect the toe.
You can mechanically check the toe in by scribing a line on the circumference of each tire on the tread surface. Then you measure the distance between the lines as close to the center line of the tire as you can on the front and back side of the tire. The toe-in is the difference in these two measurements.
Toe-in should be close to zero, and not more than 1/8 inch.
NOTE: The measurement should be less on the front side of the tire (toward the front of the car) than the rear side for toe-in.
Old Aug 21, 2006 | 06:26 AM
EHS's Avatar
EHS
Originally Posted by N0TDADYS_98
never...seen one done....
Now may be the time. The C5 needs a four wheel alignment, and is too sophisticated for some string on a jack stand.
Spend the money, and BTW, why are you removing the steering rack?
Old Aug 21, 2006 | 11:19 AM
N0TDADYS_98
steering rack removal is required to replace cam.
Old Aug 21, 2006 | 01:03 PM
EHS's Avatar
EHS
OK, that makes sense -- I thought it was suspension related.
I have personally seen a good Corvette alignment done (stood there for mine, about an hour plus on a laser Hunter).
To get it right, it's really not something you wan to be doing with string.
Take it to a decent shop, and use the modified Z06 specs.
Old Aug 21, 2006 | 08:36 PM
usd2sing's Avatar
usd2sing
please post the area/link where this info is...PLZ
To Alignment
