MAFT results so far
I suspect that I needed so much enrichment because I'm running a stock MAF that has no screen and has been ported (no divider). In any case, I think I'm pretty close now. The interesting thing was that with the 5%/6% setting, my O2's were .92 to .93. Now after going from 6% rich to 12% rich on the WOT setting, the O2's are *down* to .89 to .90. I have no idea why that should be but I've about decided that you should ignore the O2 readings because they are unreliable and focus on the timing.
I also don't think you need to drive from coast to coast three times to let the computer learn. ;) I found that about 10 miles of driving was all it took to allow the LTFT's to stabilize completely. I figure if they settled on a number and stay there when you've been driving it at different speeds, different throttle positions, etc., it's done all the learning it's going to do. Mine ended up settling on 2.3% for one bank and 0.0 for the other. That's about as close as I'm going to get with a 5% resolution on the base adjustment.
Here's the before/after dyno graph:
Mike
[Modified by mchaney, 12:13 PM 8/31/2001]
Since the BASE and WOT are additive. Just try a little different combo.. You may want to try 10% on the BASE and 0% on the WOT. Give it a shot to see if you can get rid of that dip.
But Always Always Always get the BASE set 1st. Keep WOT at 0 till the BASE is perfect. Then Add the WOT 1 click at a time if needed...
