Does your stock C5 normally run without setting DIC codes?
Old Aug 31, 2001 | 02:45 PM
ProDesign's Avatar
ProDesign
Default Does your stock C5 normally run without setting DIC codes?
There have been numerous posts about DIC codes (trouble codes ) setting and was wondering if a stock C5 normally runs without tripping codes. Mine seems to run without codes tripping. This pole assumes that all related component problems have been repaired. Therefore the following pole:
Old Aug 31, 2001 | 03:37 PM
PJW001's Avatar
PJW001
Default Re: Does your stock C5 normally run without setting DIC codes? (ProDesign)
I hope these questions are not too foolish:
1-Would I see any codes on my DIC without having to toggle thru any buttons or would they simply show up upon starting the car for example?
2-If so which buttons?
3-If I did notice any codes how would I clear them?
Old Aug 31, 2001 | 04:06 PM
ProDesign's Avatar
ProDesign
For retreiving codes check out tech section at this link:
https://www.corvetteforum.com/guides...s/ipccodes.htm
Clearing codes also in tech tech section
http://www.corvetteforum.cc/techtips...D=25&TopicID=1
Old Aug 31, 2001 | 05:51 PM
5150 BRD's Avatar
5150 BRD
My guess is that communication codes are fairly normal. Although I have not received any for quite a while. I did get a 02 sensor code the other day.
Old Aug 31, 2001 | 10:01 PM
rbeckham's Avatar
rbeckham
Despite numerous modifications to my car, these posts have me worrying that I have not had any DIC codes at all. Perhaps there is something wrong with my setup. Should I worry about it?
Old Aug 31, 2001 | 10:31 PM
Mike Siska's Avatar
Mike Siska
If everything is kosher, why would you have any DIC codes? :confused: :confused: :confused:
Old Sep 1, 2001 | 07:19 AM
TulsaVette's Avatar
TulsaVette
Default Re: Does your stock C5 normally run without setting DIC codes? (Mike Siska)
I only get a loss of communication code from time to time. Pretty normal with all the computers in this car. :chevy
Old Sep 1, 2001 | 03:11 PM
adamsocb's Avatar
adamsocb
Default Re: Does your stock C5 normally run without setting DIC codes? (rbeckham)
Have you checked your codes? I think every one is talking about the codes you read by holding the OPTIONS key down while pressing the FUEL key 4 times. The DIC will then cycle through all 11 of the computer modules in the car reporting the current and historical codes for each one.
:seeya
[Modified by adamsocb, 11:13 AM 9/1/2001]
Old Sep 4, 2001 | 10:54 AM
ProDesign's Avatar
ProDesign
Rbeck,
DIC codes will only appear when a problem or out of range condition exists.
Old Sep 4, 2001 | 10:17 PM
97silverbullet's Avatar
97silverbullet
You will almost always have codes in the DIC. All of the sensors "talk" to the computer at once. Sometimes some of the sensors don't get "heard", hence the codes. :chevy
Old Sep 5, 2001 | 01:57 PM
lodom's Avatar
lodom
I think my ex-wife would set a DIC code. Oops, wrong fourm....
Old Sep 6, 2001 | 11:35 PM
Jeff's Avatar
Jeff
Cruise-In II Veteran
I get a few codes- mostly communications - from time to time. Did you know that you can go through the DIC check codes procedure while driving?
Old Sep 19, 2001 | 10:14 AM
99 Torch Coupe's Avatar
99 Torch Coupe
Ever since I allowed the gauges and DIC to stop moving after I turn on the ignition I get no codes unless I have had a real problem. The communication codes go away after you follow this process completely in my case at least. I HATE codes :smash:
Old Sep 19, 2001 | 10:50 AM
levrac68's Avatar
levrac68
Default Re: Does your stock C5 normally run without setting DIC codes? (99 Torch Coupe)
Plenty of mods, and no codes. :flag
Old Sep 19, 2001 | 06:11 PM
intel55's Avatar
intel55
mine trips ALL the time. Not bad though . I have some mods that cause it (drag radials in the rear without any rear tire sensors). Sometimes when I first start it after it has been cold I get a "redcue power.." code , but I just turn off and restart and it is gone. That has something to do with my nitours safety gear ( I had to splice into the TAC and the TAC will throw that reduce code).
bla bla bla...... if you have mods,Iwould expect some codes, but they are usaully easy to remedy.
:cheers: :flag
Old Sep 21, 2001 | 03:03 PM
COOL Z06's Avatar
COOL Z06
No codes here either...........
Old Sep 23, 2001 | 11:57 AM
MTWallet's Avatar
MTWallet
Default Re: Does your stock C5 normally run without setting DIC codes? (COOL COUPE)
No codes here either, unless I cause them myself. I got reduced power and all that stuff when I started it after I hit the rev limiter big time blowin away a Mustang GT, but that is it.
Even with the mods and removing the MAF screen, I never get any codes. Guess my car was build on a Wednesday.
To Does your stock C5 normally run without setting DIC codes?
