Intake Help
Old Jul 2, 2006 | 12:36 PM
jaysal555's Avatar
jaysal555
Default Intake Help
I just installed the blackwing filter in my 04 c5 this morning. Everything went in good. Then I did the C5 idle relearn procedure from http://c5forum.com/diy/idlerelearn.php Now I have a CEL. Has anyone else had any problems? Now I'm wondering if I put the fuses back in before I turned it off. Would that change anything?
Old Jul 2, 2006 | 12:53 PM
hotwheels57's Avatar
hotwheels57
I recently did a BLACKWING install on my '04 Z16. I had a copy of the idle "relearn" procedure, but I did not use it. Instead, I went for a 50 mile drive at varying speeds...no CEL/codes. Verify that all connections are made, especially that there are no air leaks at the seals. Initially after the install, I thought I was done, then I saw that the silicone hose connection at the throttle body did not seat correctly. That left an almost impossible to see gap at the bottom of the throttle body.
