Help! My HVAC Doesn't Work
Old Aug 31, 2001 | 08:02 PM
DreamZ06's Avatar
DreamZ06
Default Help! My HVAC Doesn't Work
I just took delivery of my new 2002 Z06 and discovered the HVAC system is inoperative. When I turn the car on, the dual zone climate control doesn't have any display, and nothing happens when I press any of the buttons (fan, temperature control, etc.). The system just blows out hot air from the front vents. I checked the HVAC fuse for power and it was good. Does anybody know what I should check to get this system to work (where its plugged in, etc.). The dealership doesn't open until Tuesday, and I'd like to fix it myself this weekend if its something simple. I can't believe this car left Bowling Green without anybody checking this system. Any help would be greatly appreciated.
Dave
Old Aug 31, 2001 | 09:48 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: Help! My HVAC Doesn't Work (DreamZ06)
Hi there,
I did reply on your other post, so please retreive codes from the DIC in order to proceed with diagnosis.
I am absolutely sure that it was checked before it left the factory, so let us know what you have, c4c5
Old Aug 31, 2001 | 10:24 PM
Avanti's Avatar
Avanti
Default Re: Help! My HVAC Doesn't Work (c4c5specialist)
Sorry, but it's probably back to the dealer. Good luck!
Old Sep 1, 2001 | 09:59 AM
DreamZ06's Avatar
DreamZ06
c4c5specialist,
I replied to you in my other post, but in case you haven't gone there, the two codes that came out of the system were: B2252H and U1000H. When the display got to module 99 (FIVAC), it displayed "No Communication". How do you think I should proceed now? Thanks for your time! :confused: :confused:
Dave
To Help! My HVAC Doesn't Work
