A4 cooler position opinion needed.
Old Jul 4, 2006 | 03:08 PM
RED99's Avatar
RED99
Default A4 cooler position opinion needed.
I can't make up my mind if I should run this cooler like this! OR maybe should I turn in 90° and place it on the side of the radiator, instead of centered. The reason why I ask this is the fins on the cooler. If it was turned 90°, the the air wouldn't have to go over then edge of the fins, then turn 120°. It could just run up between the fins then in.
I need opinions please.
The reason I did it this way is because it gave a little more room for the Maggie intercooler. But I think it will work 90°. It wll just be tight.
