Reduced Engine power- Blown fuse #17 ??
Old Jul 6, 2006 | 05:03 PM
denverfire's Avatar
denverfire
Default Reduced Engine power- Blown fuse #17 ??
Driving down street, suddenly cars goes into REDUCED ENGINE POWER mode, get "Service traction control" on the DIC along with some " Service Active Handling codes !! ( The code was P 1518 in the DIC ) Had the exactsame thing happen 4 months ago and the Chevy dealer mechanics says it was chaffed wires on the wiring harness. They taped and sealed them all up, now 4 months later the same thing. Last time and this time, the #17 fuse was blown. This is the THROTTLE CONT. fuse. Dealer checked the TAC module 4 months ago and said it was OK, along with the battery and any possible acid leakage onto the PCM or TAC modules. This time, replaced the fuse next day, car ran good for three days, then same thing happens again- Blown fuse, Reduced Engine power and all the acitve handling and traction control codes ! Does this sound like it may be a bad grounds issue, like Bill's thread talked about?? Any ideas ? Dread taking car back to the Stealerships again!! Thanks for any input !
Old Jul 6, 2006 | 07:22 PM
denverfire's Avatar
denverfire
Anyone had this or similar problem?? I think some sort of ground issue or short somewhere, any ideas?
Old Jul 6, 2006 | 08:23 PM
bcseitz's Avatar
bcseitz
ttt
Old Jul 6, 2006 | 08:36 PM
Wt99C5's Avatar
Wt99C5
I’ve had this code before, but it was a self inflicted wound while messing around with the TB. Check out this link.. hope it hopes.
http://www.gearchatter.com/viewtopic9957.php
Old Jul 6, 2006 | 11:47 PM
denverfire's Avatar
denverfire
I think I will try the grounds, and the wires going to the throttle acuator motor and see if there are any shorts or wiring issues. Seems I can check these first before I go to the dealer as they will be charging me $96/hr for labor and diagnostic fees. Last time they said it was the TAC module, replaced it, and then the #17 fuse still kept blowing. They put my original module back in and then found the chaffed wires in the harness, this seemed to fix it til now. I'd like to try and do the things I can find out on here first, so any info is appreciated !!
Old Jul 7, 2006 | 07:10 AM
Wt99C5's Avatar
Wt99C5
Looks like there’s only one ground in the circuit "White/Black wire". The yellow and brown wires going to the throttle body are good suspects. Also, check and clean the throttle body itself.
Old Jul 9, 2006 | 11:23 AM
denverfire's Avatar
denverfire
ttt
Old Sep 23, 2021 | 01:56 AM
darkside_ofthemoon's Avatar
darkside_ofthemoon
I just started having a very similar issue with fuse 17 blowing. What was the cause of your issue?
Old Sep 23, 2021 | 10:45 AM
helga203's Avatar
helga203
His family admitted to a mental institution center. Back in 2006 when he started these thread, he couldn't figure it out and his family had enough of him. I think he's working 3rd shift at a cemetery.
To Reduced Engine power- Blown fuse #17 ??
