Alignment Problems
Old Jul 9, 2006 | 05:00 PM
bdiddo's Avatar
bdiddo
Default Alignment Problems
I getting a slight pull to the right. I have had the alignment checke and balanced 3x and still having the same problem. Tires have less than 3k miles on them. Have also checked springs-all seems good, Problem appears to have started after tires were put on (Michelin Sports). As a process of elimination the tire vendor has ordered two new front tires although that does not appear to be the problem. Any thoughts?
Old Jul 9, 2006 | 08:03 PM
VetteSiNz's Avatar
VetteSiNz
Check your brakes and wheel bearings.
Old Jul 9, 2006 | 08:35 PM
99FewteRC5's Avatar
99FewteRC5
Did they install the two new tires yet? If not cross the to frt tires and take a drive. If it pulls left now then its for sure a bad tire causing the pull
Old Jul 9, 2006 | 09:40 PM
01vetter's Avatar
01vetter
Could be the crown of the road. If castor is = on both sides and you are driving on the right side of the road crown it will pull slightly to the right. Try driving on the highway dead center on the top of the crown.
Old Jul 9, 2006 | 10:26 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
This has a bigger impact than many people realize. I find it hard to find a road flat enough to really check my alignment on the street.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 9, 2006 | 11:38 PM
bdiddo's Avatar
bdiddo
We have checked for road crown. Tires are uni-directional, therefore cannot cross which is why the vendor agreed to order two new fronts (which is also way I have always bought thru Discount Tire). I did not not consider bearings. I well check that once the tires get in. As usual, thanks for all your input. Hopefully, we'll get it figured out. My concern of course is prematurely wearing down the tires.
Ed
Old Jul 9, 2006 | 11:47 PM
99FewteRC5's Avatar
99FewteRC5
you can cross the tires just for a test, that will rule out any other problems really quick and rule out the tires or blame the tires.
Old Jul 10, 2006 | 02:21 AM
bdiddo's Avatar
bdiddo
OK- I'll try tomorrow and let you know.
Thanks for the suggestions.
Old Jul 10, 2006 | 03:15 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Hunter Road Force combined with a tech who knows how to use it will reveal the answer................
Old Jul 10, 2006 | 06:26 PM
mountainbiker2's Avatar
mountainbiker2
If switching the tires does not help. Then forget about what the alignment rack reads, it needs less castor on the left side or more castor on the right.
Steve
Old Jul 10, 2006 | 06:28 PM
jbarclay's Avatar
jbarclay
6th Gear
I have a pull to the left on my '98 that has been also aligned many times, but the clue is that the left front brake pad wears 3X faster and the left front tire wears and has to be replaced. It appears to me that the slightest vibration (road uneveness to washboard) causes the braking system to engage the left front brake slightly. This seems to be beyond the understanding of the Chevy garage guys, but we know that the system is capable of doing that in the traction control system. I now need my second left front tire and another brake job at 49,000. My only nightmare. Ideas..?
Old Jul 10, 2006 | 06:34 PM
jbarclay's Avatar
jbarclay
6th Gear
My pull problem exists whether traction control is engaged or not...
To Alignment Problems
