C6 Shifter question
Old Jul 11, 2006 | 07:52 AM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
Default C6 Shifter question
I have recently installed the C6Z06 shifter in my C5 and was wondering to those who have done the same:
Have you found that the left to right motion in the shifter feels loose and awkward?
I have gone back and checked all of the bolts were nice and tight, but there seems to be a wide range of motion in the left to right movement that just feels awkward compared to the stock C5 shifter. Am I missing something?
Any and all comments welcomed!
Old Jul 11, 2006 | 08:36 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Mine feels fine.
Old Jul 11, 2006 | 08:59 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Did you re-install the centering pin?
Pic of it (thanks Patches) :
On the left C5 shifter, it's the pin you can barely make out on the far left.
Old Jul 11, 2006 | 09:02 AM
JR_VETTE's Avatar
JR_VETTE
Here's a better picture thanks to C5Forum :
Old Jul 11, 2006 | 09:39 AM
Tact's Avatar
Tact
If you re-install the center pin the shifter wouldn't move at all.
Old Jul 11, 2006 | 07:20 PM
JR_VETTE's Avatar
JR_VETTE
You sure about that? It's installed in my C6 shifter.
Old Jul 11, 2006 | 07:51 PM
CHJ In Virginia's Avatar
CHJ In Virginia
I had a similar problem with my installation. The centering pin needs to be locked down when the shifter is installed. It insures the proper location of the base plate in relation to the rod and transmission. Make sure the bolt on the rod and shifter connection is installed per the indexes and tight. Then tighten the shifter plate bolts down evenly. Back out the centering pin and it should shift very smoothly. Enjoy.
Old Jul 11, 2006 | 08:08 PM
lostinvt's Avatar
lostinvt
I dont know what you guys are talking about...I just swapped the entire shifter in!
Seems OK, I think its worlds better then the stock shifter.
Old Jul 11, 2006 | 08:10 PM
cenzo's Avatar
cenzo
Dixie, the bolt that secures the clamp to the shift rod is not tight enough. That's the only way to induce left-to-right slop. The slot in the clamp should be barely open, maybe a millimeter at most. With the shifter in neutral, re-install the neutral pin and loosen all three bolts a little. Tighten the shift rod clamp bolt first. Make sure that the bolt is aligned with the groove in the shift rod. Then tighten the two frame mount bolts. Check for side play before reassembling the cockpit.
Old Jul 11, 2006 | 08:12 PM
cenzo's Avatar
cenzo
It IS the stock shifter - with a shorter bent shaft.
To C6 Shifter question
