I would like to occasionally shut off the airbags in a 2000 coupe. If I pull the airbag fuse to do this, will I cause any car problems with the fuse out or after reinstalling it? I assume that the airbag fault light will appear, but will it disappear (and will the airbags reactivate) when the fuse is reinstalled?
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
Why don't you get an airbag cut off switch? I have seen links for them here on the forum. I would not shut off the drivers air bag. If you will have small children in the passenger seat then I would get the switch.
I have a 2000 vert and there is a passenger air bag lock out switch located in the glove box, with a light located on the console that indicates when air bag is disabled.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Must have been a mid year change I had to install one in my coupe.
