< < < Basic YET Technical question: Oil Changes after Hibernation > > >
Old Jul 12, 2006 | 08:01 AM
Vette_Fan's Avatar
Vette_Fan
Default < < < Basic YET Technical question: Oil Changes after Hibernation > > >
Hey guys, I need some help.
I was away on a trip for about 6 months. I left the car without changing its oil, and it had 2300 or so miles on the oil.
The oil has been sitting in the car, while it was parked in the garage for last 6 months. So, do I start the car with the old acidic oil, and then change it. OR do I simply drain the old oil and change it? I'm afraid of the rust, oxidation, and nuteralization that occurs with old & acidic oil.
So far I haven't got a real straight answer to this. Looking forward to hearing from you guys..
Thanks for the help.
Old Jul 12, 2006 | 08:26 AM
VetteDrmr's Avatar
VetteDrmr
Oils not going to change much in six months. The extra amount of water (i.e. acid) that's going to get into the oil while sitting is nothing compared to the amount of water that the oil experiences via blow by. So, the way the engine was driven beforehand (short trips, lots of water in the oil vs 30 minute cruises that can dry the oil out) will be more of a contributor.
However, do what makes you feel comfortable. If you want to change the oil before, then do that. If you want to run it, then change the oil, do that. Heck, if the engine sees mainly hwy miles and was put up after a 30 minute run or so, just run the oil until you normally change.
Now, for a more informed opinion, you could always contact the folks at Blackstone labs, they could give you some good advice.
HTH, and have a good one,
Mike
Old Jul 12, 2006 | 08:34 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I think the general consensus is that the oil is fine. As stated above if it makes you sleep better at night, go ahead and change it. Good luck on your decision.
Old Jul 12, 2006 | 09:28 AM
Vette_Fan's Avatar
Vette_Fan
Anyone knows of a way to contact Blackstone Labs ?
Thanks...
Old Jul 12, 2006 | 02:15 PM
Vette_Fan's Avatar
Vette_Fan
ttt
Old Jul 12, 2006 | 02:19 PM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
I just googled the name "Blackstone Labs" and came up with their site as first hit, give that a try.
Old Sep 29, 2006 | 03:41 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default oil
The engine has to be operating to accumulate anything other than moisture. Condensation occurs with humid air
if it wasn't 2 humid, change oil and forget it.
To < < < Basic YET Technical question: Oil Changes after Hibernation > > >
