DIC codes - Need help Deciphering
Old Sep 2, 2001 | 03:08 PM
Corvette Poor's Avatar
Corvette Poor
Default DIC codes - Need help Deciphering
Any help will be greatly appreciated !
10PCM - P1626H
AO-LDCM - B2252H, B2282H, 2284,2272,U1064H,U1016H
A1-RDCM - B2253H,2283,2285,U1064H,U1016H
BO-RFA - C2105HC, 2110.2115,2120
Old Sep 2, 2001 | 03:26 PM
whip383's Avatar
whip383
Default Re: DIC codes - Need help Deciphering (Corvette Poor)
I just emailed you all the codes.
Good Luck,
Chan
Old Sep 2, 2001 | 04:47 PM
mikeyc6's Avatar
mikeyc6
The P1626 is a fault that is set when the resistor code in your key is not communicated properly to the PCM. It's basically a security system code.
The C coded relate to all four tire pressure sensors. It may be time to retrain them. I believe these codes are set when the PCM doesn't get a message from the tire pressure sensors when it expects to.
The other (B and U) codes I think are pretty typical although I didn't look those up. I know that all the U codes you mentioned and at least some of the B codes can pop up for no reason and a lot of people get those. I don't think any of them set the "Service Vehicle Soon" message; they are silent codes.
Mike
Old Sep 2, 2001 | 07:16 PM
Corvette Poor
Default Re: DIC codes - Need help Deciphering (mchaney)
O.K. Thanks for all that valuable info. Now another question...The tire pressure sensors send a radio signal out.... What receiver receives that signal ? What is it called ? Is it the same receiver that receives the key fob signal to lock/unlock the doors ? Anyone have a part number for this unit on a 98 model ? Thanks again ! :confused:
Old Sep 2, 2001 | 07:36 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Remote Door Lock Receiver,P#10422088 located behind left rear inside quarter trim panel...Yes,this receiver is used for keyless entry and low tire warning system...
To DIC codes - Need help Deciphering
