A4 ATF change question
Old Jul 13, 2006 | 08:21 PM
Stevedore's Avatar
Stevedore
Active Streak: 90 Days
St. Jude Donor '03-'05-'06-'07-'08,'11 thru '17, '21
Default A4 ATF change question
I'm planning to change the fluid in my A4 tomorrow. Do I put the new pan gasket on dry, or is some kind of sealer recommended?
Tanks.
Old Jul 14, 2006 | 11:07 AM
blown in n.c.'s Avatar
blown in n.c.
You will need a gasket and sealer
It's black--not sure what brand or exact name though.
Glad to help
Old Jul 14, 2006 | 11:30 AM
MR1911's Avatar
MR1911
You do not need a sealer, but if your new gasket does not want to lay flat (which it wont )use a gasket tacking spray to hold it in place on the pan as you put it in place.
Old Jul 14, 2006 | 12:31 PM
jdaniel2509's Avatar
jdaniel2509
Can I ask a stupid question? How do I put trans fluid in my 98 A4?
Old Jul 14, 2006 | 01:05 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Do not use sealer on the gasket. The pan has a raised rib that forces the gasket against the transmission . Will seal fine, torque to 8# starting in the middle of the pan and working outward.
Old Jul 14, 2006 | 01:08 PM
OhioDave's Avatar
OhioDave
http://www.idavette.net/techno.htm
I used the instructions in the c5 tech section. Part 2 Worked perfect.
To A4 ATF change question
