Turn Signal Problems
Old Jul 13, 2006 | 09:45 PM
C5Jimmy's Avatar
C5Jimmy
Default Turn Signal Problems
I did a search, and found nothing about turn signal problems on C5's (Sorry if this is a dupe, but at least its not another Column Lock or Vararam vs. Blackwing thread!)
ANYWAY...Sometimes my turn signals won't work, it just happens intermittently, with no rhyme or reason. They won't work at all, then a few seconds, or sometimes minutes later they will work. This can happen once a month, or twice in one day, although in my 7 months of C5 ownership, its only happened 4 or 5 times.
BTW I own a 2000 FRC, 100% stock, no tune, mods, etc...
Anybody else come across this problem? Any ideas?
Thanks for any input!
Old Jul 13, 2006 | 09:58 PM
patton's Avatar
patton
St. Jude Donor '09
cycle the 4 way switch or jiggle it the binkies will winkie
Old Jul 13, 2006 | 10:39 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
Same problem on my 99, the hazard switch is the problem. It’s $32 at the dealer. EnglandGreen posted this how-to.
http://forums.corvetteforum.com/show...77&postcount=8
PS: do your search on "flasher" in the Archives, you'll get more hits
Old Jul 15, 2006 | 08:56 PM
Gene Wolf's Avatar
Gene Wolf
It's the hazard switch on mine. I have to punch it in and out a few times to get the turn signals to work... I know someone gave a great description with pictures of how to r&r the hazard switch... Yeah, here they are:
http://forums.corvetteforum.com/showthread.php?t=860333
http://www.vetteessentials.com/instr...zel_howto.html
It's not impossible, but it's not for the inexperienced backyard mechanic, either.
YOU CAN DO IT!~!!!!!!!
Old Jul 17, 2006 | 12:34 PM
Len16's Avatar
Len16
I have the same problem.
One question before replace the flasher unit.
Should I check anything else first to be sure I have to replace the flasher unit?
Old Jul 17, 2006 | 01:57 PM
wwwFLA's Avatar
wwwFLA
Default First
Replace your turn signal bulb. I was using the hazard switch work around for several weeks before the bulb gave an indication it was going bad. Bulb replaced 4 months ago, no more problem.
Old Jul 17, 2006 | 03:51 PM
Ron_CCDV's Avatar
Ron_CCDV
I have had the same problem for a year, just happems when it feels like. If I push the 4 way switch it will sometimes start the turn signal to work. It only happened about 5% of the time, now it's about 75% of the time. I just picked up a new 4 way switch from the dealer today.
Old Jul 17, 2006 | 09:15 PM
Cruncher's Avatar
Cruncher
And the GM quality keeps going and going. How many years has GM been making turn signals. Pathetic, really pathetic.
Old Jul 18, 2006 | 10:55 AM
Len16's Avatar
Len16
Thanks for all the help. I'll do the replacement of the flasher unit.
I also own a 2001 Chevy Malibu.
It also had the same flasher/turn signal problem after about 4 years.
Old Aug 12, 2006 | 03:40 PM
Sodium's Avatar
Sodium
Default How to Replace Bulb
Ok all...sorry for the dumb question, but how do you replace a turn signal bulb? I can't find an easy way to get at it.
To Turn Signal Problems
