:seeya Clutch
Old Jul 13, 2006 | 11:34 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
Default :seeya Clutch
Yes that is right I believe that my clutch is now lost and gone forever..... I cant believe it.... ok well maybe I can, I ran 4 trips down the track... being pretty easy on the clutch, changed the fluid between 2 and 3, because I was having sticking problems, All was ok then.... I went home and on the way I layed the smack down on this ricer *** eclipse turbo who thought that his shi==p was fast, then when pulling outta a parking lot after talking with the guy it would nit stay disenguaged, the car would take off with the clutch pushed in, and continued to do this all of the way home... parking really sucked... So is this the end of the road for my poor clutch???
Old Jul 13, 2006 | 11:44 PM
brookman's Avatar
brookman
That is backwards - a bad clutch will slip when engaged. It sounds like you have air in the system.
Old Jul 14, 2006 | 11:50 AM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
what is the best way to properly bleed the clutch in these cars?
Old Jul 14, 2006 | 02:12 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I had something similar happen on another vehicle. One of the springs in the clutch disk hub had popped out.
Old Jul 14, 2006 | 02:15 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
arggg I need to figure this crap out.....
Old Jul 14, 2006 | 02:21 PM
willyfastz's Avatar
willyfastz
Easiest way would be to take a Mighty Vac and push the air out. It's really easy to do, if that does't solve it you probably have presure plate problems like stated earlier.
Old Jul 14, 2006 | 02:29 PM
mdhmi's Avatar
mdhmi
Were you letting the car cool down for 30-40 minutes inbetween passes at the track? I found that very helpful for keeping a clutch alive.
Old Jul 14, 2006 | 03:46 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
It was closer to an hour, between runs
Old Jul 14, 2006 | 11:51 PM
patton's Avatar
patton
St. Jude Donor '09
does it feel different like nothing there or more than usual resistance if the later big bucks if whimpy maybe air in system some hyd. can be gravity bled but long wait and if you run master dry ya have to start again and dont be bop with fluid ya shake the stuff up ya be waitin for that air to calm down . idealy 2 people 1 slowly pumps pedal then holds down yell preasure and hold down #2 guy open bleeder till fluid comes out then close bleeder # 1 repeat # 2 repeat till #2 gets a pure fluid jet no air you can even hear it when its clear
Old Jul 15, 2006 | 09:31 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I have a stock LS1 clutch and flywheel for sale. best offer
18500 miles
Old Jul 15, 2006 | 11:41 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
Thanks but no thanks on a used ls1 clutch with 5k miles more than mine, which wont hold the power that I will have in a month, especially being that an ls7 wont hold it
To :seeya Clutch
