Trans. cooler hard lines
Old Jul 15, 2006 | 11:53 AM
RED99's Avatar
RED99
Default Trans. cooler hard lines
I just install my cooler with AN fittings and rubber hose, but now I am thinking hard line will be more trouble free and longer lasting.
Is there any problem running aluminum fuel line tubing with AN fittings, for the trans cooler? OR should I use steel lines?
Old Jul 15, 2006 | 07:30 PM
IM QUIKR's Avatar
IM QUIKR
Don't use aluminun tubing for the tranny lines. They will vibrate at the coupling and break off. If you use any hard line, make sure it's steel.
Old Jul 16, 2006 | 09:31 PM
FRED HAMBLE's Avatar
FRED HAMBLE
What cooler did you install? Was it an easy job. Several people told me not to install a cooler as it does not buy you much and it is difficult to install? Any truth?
thaks
FRED
Old Jul 16, 2006 | 09:36 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Thats pure craziness..Hopefully that person doesnt work on your car..
They work VERY VERY well.
thaks
FRED
Old Jul 16, 2006 | 10:32 PM
RED99's Avatar
RED99
OK, thanks for the warning. I'll pull them off and go back to using the rubber hose I already have made up. I was actually wanting steel line, but they was out of stock where I bought the fittings.
Fred Hamble: I used a B&M 70266 cooler. And no it's not that difficult to install, IMO. I am using all AN fittings, and I am not cutting the stock lines or anything. And yes they do drop the transmission fluid temp.
Old Jul 16, 2006 | 11:17 PM
1965imp's Avatar
1965imp
I'll go on record here...TRANS COOLERS work very good on the C5-A4
Old Jul 17, 2006 | 03:19 PM
GA Country Boy's Avatar
GA Country Boy
I agree. I run a B&M with a fan and before I couldn't run in hot weather traffic without my 4L60E overheating. I also installed a B&M larger tranny pan which adds three quarts of fluid AND a drain plug so you can change the fluid yourself really easy.
Old Jul 17, 2006 | 03:27 PM
LRD VDR's Avatar
LRD VDR
Do you have a link or a part number for that pan? and I am guessing it came with a differant filter too?
Shahram
Old Jul 17, 2006 | 04:22 PM
Dirty Howie's Avatar
Dirty Howie
Shahram
You will be able to find the pan by searching B&M on the Summit Racing site.
The filter that goes with the pan is: GM filter p/n:10287788
DH
Old Jul 17, 2006 | 04:30 PM
LRD VDR's Avatar
LRD VDR
DH
Does it have a fill plug or just a drain plug?
Shahram
Old Jul 17, 2006 | 04:51 PM
MattB's Avatar
MattB
Ya, getting to and replacing your AC belt idler and tensioner... Hard enough for me with the rubber ends to the lines....
Old Jul 17, 2006 | 05:13 PM
GA Country Boy
Shahram
I got mine from Summit Part # BMM- 70260 cast aluminum $166.95 for 4L60/4L60E. Everything is included and you don't need a new filter they supply an extension for your pick-up. It adds 3 quarts and a drain plug and fill plug.
Jeg's has it under Part # 130-70260.
Old Jul 17, 2006 | 05:35 PM
b98's Avatar
b98
thanks good info.
To Trans. cooler hard lines
