Is this common issue for a C5?....
Old Jul 15, 2006 | 09:08 PM
bheston's Avatar
bheston
Default Is this common issue for a C5?....
The round plastic trim around my key slot ignition switch is loose. It drives me crazy. Is this a common thing with a C5? Has anyone else experienced the loose plastic around the key slot ignition switch?
Old Jul 15, 2006 | 09:36 PM
rws.1's Avatar
rws.1
not here...
Old Jul 15, 2006 | 09:58 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I broke mine 2 years ago. It drove me nuts as well. You need to remove the knee bolster to install the new one. The bezel is cheap, the work is a PITA.
Old Jul 16, 2006 | 05:34 PM
brookman's Avatar
brookman
Lift it a little and put a couple of dabs of black silicone in a couple of spots. press it in place and wipe up any excess.
Old Jul 16, 2006 | 07:34 PM
jim dodd's Avatar
jim dodd
Default loose part
mine is loose but dosent make any noise
Old Jul 16, 2006 | 07:38 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Mine's loose too. Definitely under-engineered.
Old Jul 16, 2006 | 08:25 PM
VetteDrmr's Avatar
VetteDrmr
Easy fix and usually quiets any rattles.
Have a good one,
Mike
Old Jul 16, 2006 | 08:33 PM
Billdog350's Avatar
Billdog350
Mine's bad too, I might do the silicone trick.
Old Jul 17, 2006 | 07:12 PM
bheston's Avatar
bheston
I was going to do the silicone trick but I elected to order a new one from the dealer. The part number for an 2002 is 2852046. My dealer overcharged (I mean CHARGED) me $22.55. I looked it up on GM Parts Direct and it's $9.38+$9.95s/h = $19.33.
Old Jul 17, 2006 | 08:12 PM
ytwokc5's Avatar
ytwokc5
Mine is loose also... I attributed it to the work that was done when the previous owner had the column lock recalls performed.....
Old Jul 17, 2006 | 08:50 PM
Cruncher's Avatar
Cruncher
Why would you want to mess around with the quality that GM's engineers built into the car?
Old Jul 18, 2006 | 05:56 AM
Hatdude's Avatar
Hatdude
Mine not only turned but eventually cracked and fell apart completely.
$17 for a new one and under 30 minutes of work and it's new again.
To Is this common issue for a C5?....
